| | #1 |
| Rock Stacker Join Date: Nov 2005 Location: Indiana
| Ok, I just received my TLT kit in the mail today, and I started my project. I am using the Dodge Powerwagon body (wheelbase is just about 12in.). I bought Traxxas Revo links (part no. 5319) and the wheelbase is about 13 1/2 inches. What other links should I use? I also have a bronco body, which is just about the same wheelbase. Bulu2 chassis Tmaxx shocks Tmaxx sliders Pede tranny Revo links TLT axles Moab 2.2 with HPI wheels Bronco or Powerwagon body |
| Sponsored Links | |
| | #2 |
| RIP Buster ![]() ![]() ![]() Join Date: Mar 2004 Location: Norcal
| Get these links and you should be right at 12.5" wb with the Bulu2. http://www2.towerhobbies.com/cgi-bin...?&I=LXHFV7&P=7 |
| | #3 |
| RCC Addict Join Date: Nov 2004 Location: Redding, CA
| I just used the some stock TXT links. |
| | #4 |
| I think the TXT links are longet than the revo links.....arent they? |
| | #5 | |
| | #6 |
| Quarry Creeper Join Date: Feb 2004 Location: Mobile AL
| Not sure about the TXT link length, but the TRA5318 are about 1/4 inch shorter than the TRA5319 so that would get you down to 13" you may have to make some or drill holes in the stock chassis! Later, Jake |
| | #7 | |
And the 5318 links are OVER a full inch shorter then the 5319 links. 5318 Specs: Length 4-1/16" (102mm) end-to-end 5319 Specs: Length: 5.4" (137mm) end to end including rod ends | |
| | #8 |
| Pebble Pounder Join Date: Nov 2005 Location: Allentown/West Chester
| i'm just makin mine, it was 5 dollars for the materials, #6 32 rod and 3/16 Al tube, cost me 5 bux and should have enough for all 8 links |
| | #9 |
| Where did you get the materials to make your own? Home Depot? I have never made my own |
| | #10 |
| Pebble Pounder Join Date: Nov 2005 Location: Viva Your Mom!!
| i just made 4 links out of a thread rod and a brass square tubing, and you need to make the threaded rod a little bit longer for the ball cup to screw onto |
| | #11 |
| RCC Addict Join Date: Jun 2004 Location: Down South Hidding From Everyone
| i use 6/32 threaded rod and 1/4 brake line tubing and braze nuts on the so the threaded rod don't move. |
| | #12 |
| Quarry Creeper Join Date: Jun 2005 Location: Northern CaliFOOLya
| im going to use, 6-32 threaded rod, traxxas ball ends, and some 3/16 brake-line. does anyone know what legnth i would use to make a proline 72 chevy c10 look right? |
| | #13 | |
| Thread Tools | |
| Display Modes | |
