Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Possible stampede tranny source?
Old 01-06-2006, 07:42 AM   #1
Default Possible stampede tranny source?
http://www.buytraxxas.com/default.php?cPath=1_7_672
Theres alotta parts there i wonder if those are all the parts you would need to build a whole tranny?
Rockinrockcrawler is offline   Reply With Quote
Old 01-06-2006, 08:28 AM   #2
yes everything you need is there, just get the bearing else where they are alot cheaper.
I'm gonna go to hobby town first since they are the same price as traxxas and about 2 min away.
You need the halves, the idler gear, the complete diff with planetaries, the top gear 6 ball bearings, and a slipper gear shaft.
Go to the spur gears section on buy traxxas and you can get a spur gear adapter instead of a slipper clutch (3 dollars vs 1 along with your spur and pinion
Brian, aka XJFanatic.com is offline   Reply With Quote
Old 01-06-2006, 12:34 PM   #3
Looks like it doesn't have all the screws either. It lists the 3mmX8mm ones, but there are a bunch of other ones for hte case halves and such. I also didn't see anything for the slipper clutch or spur gear. Or the u-joints for the driveshafts. Pretty complete, but not total. I put a thread in the newbie section about pede screws and got a diagram of a complete tranny. That has EVERYTHING you need to piece your own; but it might be cheaper to just buy from in the vender section.
rerock is offline   Reply With Quote
Old 01-06-2006, 01:09 PM   #4
ITL
FYI,
You can download (pdf file) the exploded view of the Stampede tranny, with part numbers, on the Traxxas website. You can also get a full parts list and retail prices of said parts. Take a look at the box on the top right of the page...
http://www.traxxas.com/products/elec...x_stampede.htm
HTH
ITL is offline   Reply With Quote
Old 01-06-2006, 01:17 PM   #5
like i said with the spur gear adapter go to spur gears on buy traxxas page, as for screws go to the LHS, or even a small hardware store or fastner store, gonna cost just bout the same ordering it through traxxas or the venders section. I'm gonna try to get everything at LHS since i'm sick of paying shipping and should have cash for this item. Oh and the driveshafts are under drive line...
Old 01-06-2006, 02:00 PM   #6
Yea looks prett complete to me... just use some Dubro hardware from your LHS or order it online, and use a Sliper adapter from the older pede... its in the parts list at towerhobbies...
Later,
Jake
JakeDaSnake is offline   Reply With Quote
Old 01-06-2006, 03:55 PM   #7
yeah i priced it with those prices and it came out to 49 dollars with spur gear and pinion, so locally i should be able to get it for the same cost.
Old 01-06-2006, 04:01 PM   #8
Did you read the FAQ? Should have the pede tranny parts listed out. Plus there is a shop in oregon selling a pede tranny bundle.
Plays_with_Toys is offline   Reply With Quote
Old 01-06-2006, 04:19 PM   #9
Default Pede tranny parts list
I posted this on the FAQ thread but thought it may be useful here too:
I found a link elsewhere in the forum that listed all the parts required to build a pede tranny (minus screws). I used that list to compile my own with part numbers and prices from Tower:
Stampede Differential gear #2388(T#LXJH15): 10.99
Top shaft #1993(T#LXJJ89): 2.89
Top shaft gear #3195 (T#LXJF37): 2.89
Top Shaft Gear #3195X Hop-Up (T#LXJF3: 5.79
Long half shafts #1951 (T#LXJJ82): 5.79
Idler gear #1996 (T#LXJJ92): 2.89
Idler Gear #1996X Hop-Up (T#LXJJ94): 10.99
Idler gear shaft #3691 (T#LXJK65)(comes with transmission halves): 7.69
Yokes #4628 (T#LXJJ77) (plastic): 3.89
Yokes #4628X (T#LXJG59) (steel): 17.99
5x11 bearings (6 needed): 18.00 (2.99 ea.)
spur gear adapter #3693 (T#LXJK67): 2.89
slipper clutch set #4615 (T#LXJK87): 16.19
The number in parentheses(sp) are the tower part numbers.
The part numbers with the trailing X are used to replace the ones without the X. The manual states that you should not mix these parts i.e. If you use the 1996X part, you need to use the 4628X part.
The bearings are prices from my LHS and are actually a little more expensive than the Tower DuraTrax brand.
Hope this helps.
gone_wheelin is offline   Reply With Quote
Old 01-08-2006, 05:19 AM   #10
excuse me for soundin like a complete retard.....but will all those parts compile into a comlete pede tranny? jw thx
Texas Rebel is offline   Reply With Quote
Old 01-08-2006, 11:15 AM   #11
Axial Team Driver
Brandon's Avatar
Did you read his post or just decide it was too long and not read it?
Look
Brandon is offline   Reply With Quote
Old 01-13-2006, 10:03 AM   #12
crash's Avatar
Ok so first off. I am no where near a LHS so does anybody have any online source for the screws?
Also with the 84/87 toothed spur gear that comes with #3693 what pinion options do I have? I have searched on tower and there are so flippin many my head is going to explode. I see peeple running something like a 12t but not 100%...
Thanks got all the #'s sitting in my wish list,lol...
crash is offline   Reply With Quote
Old 01-13-2006, 10:39 AM   #13
I get all my screws and the local home improvement center. Do you have an Ace, Home Depot or Lowes near you?
Old 01-13-2006, 11:29 AM   #14
crash's Avatar
So this is just a self tapping type screw? I also forgot I have a bunch of 3x10mm screws left over from my TLT-1 Will those work?
Old 01-13-2006, 12:54 PM   #15
I used 6-32 allen screws to hold the case together. I am not sure of the length but they were approx. 1". The remaining screws were button head screws, I think they were 4-40 screws for around the perimitter of the case. You can also check out the exploded view of the trans and parts at:
Tranny - http://www.traxxas.com/products/elec...pede_trans.pdf
Parts - http://www.traxxas.com/products/elec...pede_parts.pdf
Hope this helps.
Old 01-13-2006, 08:32 PM   #16
31st place in 2006 Nats!!
toyofast's Avatar
Why don't people SEARCH???
New 'Pede tranny hook up deal....
toyofast is offline   Reply With Quote
Old 01-13-2006, 09:05 PM   #17
crash's Avatar
Ok, so whats your point? I have read that thread and is there any info that I asked? I don't have time to sit on the phone durring bussiness hours and I don't own a fax--so what good is that to me? Thank you for your response anyways...
Thanks gone_wheelin
Old 01-13-2006, 10:48 PM   #18
toyofast's Avatar
Thanks gone_wheelin
Crash, good to have you on RCC, look forward to your build up(s).... if they are anything like your real(1:1) rigs then we will all be impressed and look forward to 16 pages of build-up images and tech.
The point is that all the info is out there adn has been out there. Ryan(rbgerrish) is a vendor on RCC and can be contacted via email or PM's and he can sell you a complete tranny or other tranny related items.
Old 01-13-2006, 10:56 PM   #19
crash's Avatar
Trust me, I have been serching till my **** brown eyes have turned almost blue
I have been eyeballing building a chassis of some sorts, but thats trying to squeeze the time in between my shop time For now just looking to build a decent rig I can carry in my own rig for those times when somebody is broken down,lol...
Cool, thanks for the info on Ryan and I will try going that route
Old 01-13-2006, 11:05 PM   #20
toyofast's Avatar
You'll have to build a TLT based rig, small yet goes anywhere. We normally take them on trail rides too.
Ryan is one of the coolest people around. Very helpfull and did I mention he's a Mog guy? He runs around up in your neck of the woods often with his Mog and his Mog buddies.
