| | #1 |
| Quarry Creeper Join Date: Mar 2004 Location: 18" from computer screen
| In the used case at the local track they had a t4/b4 tranny. I got that and a new spur and pinion as well as 80wt for 60 bucks. Weighs next to nothing and is tiny! I'm not sure if there will be sufficient room to use a screw to lock the differential, is there anything else that will do the trick? |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Feb 2004 Location: Mobile AL
| Just spread some JB Weld all inside the diff gear and on the outdrives and take out the thrust bearing (the little washers and balls on the diff screw) and put the screw back in. Then tighten really tight, lol. Just dont strip it... its a 2-56 screw into an aluminum locknut. Later, Jake |
| | #3 |
| I joined the Band! Join Date: Sep 2005 Location: Tampa
| so will a associated stealth tranny work?] _Jason |
| | #4 | |
| Thread Tools | |
| Display Modes | |
