| | #1 |
| Newbie Join Date: Aug 2005 Location: ky
| i got a set of tlt axles... ok now i need some hlep..i am new to buliding..... hear are some???? 1.how long/wide to make my frame....(i will prolly amke 2 frames a tuber and a scale type some give me some specks on how long/wide i should make both) 2.what type of esc should i use??? onley 2ws for now but will up grade 2 2ws later 3.what tranny? 4.what batts looking to get the longest run time 5.witch motro? and if ya all see eney thing eles i need Plz tell me.. i will post pics as soon as i get my axles in.. Last edited by from the south; 01-09-2006 at 12:08 AM. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Feb 2005 Location: Wheeling
| | #3 |
| bad links/ |
| | #4 |
| Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
| | #5 |
| RCC Addict Join Date: Feb 2005 Location: in my house
| In the upper right corner of your screen right underneath the ad there is a search button. Click on it. Type in TLT. You will be surprised how much information you can find. Hope this helps. |
| | #6 |
| http://www2.towerhobbies.com/cgi-bin...?&I=LXJK62&P=7 could i use this rims ..what all do i need to do to mount them to my tlt axles |
| | #7 |
| Pebble Pounder Join Date: Sep 2005 Location: minocqua
| you are going to want the fronts because they have more offset, which will give you more width. |
| | #8 |
| Rock Crawler Join Date: Sep 2004 Location: Santa Rosa
| I just picked up 2 sets of the fronts and narrowed them via the inside bead. I haven't run them yet as my project is not complete but so far so good. You will need to either drill out the center a bit to get the wheel nut to tighten properly or get the blackfoot axles. Also, they say they are dyable but don't believe it; well at least not black. I tried to dye mine black and they came out a dark burgandy instead. I also drilled 3 small holes around the middle of the wheel to allow air in and out. |
| | #9 |
| For building ideas you might want to read through the top two or three threads (the FAQ and the How-To) . Lots of great information there. Ane definitely use the search function. You can answer most of your questions with a simple search. |
| | #10 |
| will a servo off of a t maxx work on my truck???? |
| | #11 |
| Rock Crawler Join Date: Dec 2004 Location: Grand Forks, ND
| yup the traxxas 2055s will work. i ran two of them on my truck. but if you can i would try to get a higher torque servo. Because although they could turn the tires they didnt do the best job at it. |
| Thread Tools | |
| Display Modes | |
