Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Searched, read through 200 posts with no luck
Old 01-09-2006, 08:28 AM   #1
Default Searched, read through 200 posts with no luck
I remember reading through a post before on locking the pede trans. But I know jbweld, and glue but i remember reading bout cutting one of the nubs off where the gears rest so that they just mesh. Anyone got any info on this.
Brian, aka XJFanatic.com is offline   Reply With Quote
Old 01-09-2006, 08:40 AM   #2
I don't know. I just used JB weld.
rerock is offline   Reply With Quote
Old 01-09-2006, 08:40 AM   #3
Thats what I did.
Use a dremel and grind down the nubs in the diff and let all the gears sit flush with each other.
Don't grind the nubs completely down, but low enough for the gears to mesh, with each other and both outputs. I may have some pics on my digicam of the final product.
It is plenty strong. Right now my fuse (most probable breaking point) seems to be the "reversed gear in diff method of locking the TLT axle". Somehow when I really get on my TLT, that seems to slip out first.
CronusTRD is online now   Reply With Quote
Old 01-09-2006, 09:55 AM   #4
cool, thanks...
Old 01-09-2006, 08:51 PM   #5
Jb weld...works for me!
jedrattle is offline   Reply With Quote
Old 01-09-2006, 09:22 PM   #6
i quick steeled it, was gonna just do the gear but realized with the way i beat on **** that it had nothing to hold it down in place, so the quicksteel works
Old 01-09-2006, 09:50 PM   #7
I used quicksteel too. The way I see it, something that hard (as long as you let it set) will not let gears move. you'd strip a gear before you blew out your locked diff.
Plays_with_Toys is offline   Reply With Quote
Old 01-10-2006, 01:20 AM   #8
Actually I bet the star that holds the gears will snap first. I've busted them in both front and rear of my RBX. I heard something rattling around and took them apart to investigate and then I removed the broken part and re-assembled. They are now lighter and still holding up.
rckjeep is offline   Reply With Quote
