Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: has n e one done this.........
Old 01-10-2006, 10:20 PM   #1
Default has n e one done this.........
i need help mounting a stealth tranny in a stock chassis and waswondering if n e has done it b4? and maybe help me out (pics and some instructions)
thanx in advance
hansom is offline   Reply With Quote
Old 01-11-2006, 04:53 AM   #2
No but you can easily make a frame that will take a stealth tranny. I made mine with aluminum I got at the THC for $10 and I still have lots of scraps left over. I used the stock center supports. Thers no sense messing with the stock plates but if you do Im pretty sure that you would be able to find another set localy.I have a set still in the original package.
crawlinthe808 is offline   Reply With Quote
Old 01-11-2006, 07:13 PM   #3
Gold Star Baby Momma!
Yes, it can be done
No, you don't want to do it because of high center of gravity.
I have a stealth tranny in mine and it is tippy and doesn't have good ground clearance.
Kevin
Tuffguy is offline   Reply With Quote
Old 01-11-2006, 08:05 PM   #4
Gold Star Baby!
DISTURBIN' tha PEACE's Avatar
Here are some ways. Although it's a pede, it don't matter. You still gotta drill some holes.
Just put the plates together w/ posts & see where the tranny needs to go.
Measure Measure again drill & cut. Done.
DISTURBIN' tha PEACE is offline   Reply With Quote
