Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Flex Problem
Old 01-11-2006, 06:34 PM   #1
Default Flex Problem
If I lift up the drivers side rear it works fine but if I lift up the passangers side rear it is extremely stiff.
Here is a pic if it helps any.
superman0604 is offline   Reply With Quote
Old 01-11-2006, 06:54 PM   #2
it might be that u built the shocks with diff oil in each shock
or if u got them from some were they had diff type of oil in it
iwantoffroad is offline   Reply With Quote
Old 01-11-2006, 07:08 PM   #3
If I compress the entire rear axle it moves fairly easy, same with the driver's side, but when I compress the passangers side alone it is stiff.
Old 01-11-2006, 07:36 PM   #4
Is your driveshaft binding? Is the slip too long? Does it bind with the links?
double check valving and spring rates.
CronusTRD is offline   Reply With Quote
Old 01-11-2006, 07:55 PM   #5
I think I figured out what is causing it. When I flex the passenger side the axle moves towards that side and the other shock has to flex. What is causing the axle to move towards that side.
Old 01-11-2006, 08:51 PM   #6
1 man, 2 sons
Unimoger's Avatar
move your shocks on the outside of the chassis and put spacers on them.
Unimoger is offline   Reply With Quote
Old 01-11-2006, 08:55 PM   #7
If I move the shocks to the outside then they would be angling out. How they are mounted now they are straight with chassis.
