Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: TLT Tuber Finished... Pic...
Old 01-13-2006, 11:05 PM   #1
Default TLT Tuber Finished... Pic...
Well I Finally got the TLT Tuber project I had goin finished tonight specs are:
- TLT Axles, locked diffs
- Pede tranny
- Custom Tube Chassis
- 4 wheel steering
- RPM Front pede wheels, Pro-Line Moab 2.2's w/ Losi foams
- TCS wheel wideners (12 inches wide)
- 13" WB
There are more pics and the biuldup in the Small Scale Crawler forum...
Pic:
Let me know what yall think!
Later,
Jake
JakeDaSnake is offline   Reply With Quote
Old 01-13-2006, 11:16 PM   #2
beautiful
fuzzhead is offline   Reply With Quote
Old 01-14-2006, 12:13 AM   #3
Live,Eat,sleep RC
RcBro's Avatar
very nice!!
You make the chassis yourself
RcBro is offline   Reply With Quote
Old 01-14-2006, 03:19 AM   #4
Thats pretty.
Old 01-14-2006, 04:41 AM   #5
2006 2.2 National Champ
BENDER's Avatar
Moved to Small Scale.
Nice work on the build. The only thing you may need to change is mounting the lower shock mounts on the axles instead of the links. Most shafties suffer serious torque twist with the shocks mounted to the links.
BENDER is offline   Reply With Quote
Old 01-14-2006, 08:27 AM   #6
Thanks guys...
Bender: I was thinkin about that while I was assembling it last night, lol, but I cant mount the shocks to the axle unless I shorten the WB... its 13" right now so If I go to 12 or 12.5 It should work...
Thanks for the heads up!
Later,
Jake
Old 01-14-2006, 01:16 PM   #7
Wow! Its so simple and elegant. I love the droop suspension too. Did you cut the springs or use buggy springs? Definately one of the better looking TLT tubers out there.
Plays_with_Toys is offline   Reply With Quote
Old 01-14-2006, 05:15 PM   #8
that came out looking awsome keep the pics coming too
rocpede is offline   Reply With Quote
Old 01-14-2006, 06:33 PM   #9
Looks nice and simple, good looking rig. Must be light.
BrandO is offline   Reply With Quote
Old 01-14-2006, 11:33 PM   #10
Thanks A lot guys!!! Its 5.2lbs with a 540 stock motor, the Battery is a 2/3A 1100mah 6 cell and the ESC and Reciever dont wieght that much Im shooting for under 6.5lbs!
I'll hopfully get some action shots when my 12t pinion comes in next week!
Later,
Jake
