Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Well its done....Thank God!!!!!pics...
Old 01-14-2006, 10:25 PM   #1
I joined the Band!
Default Well its done....Thank God!!!!!pics...
clod axles w/ stock 540's waiting for integys, RC10T rear shock tower chassy, 3 linked, integy piggybacks, 12.25in WB , 11.25in wide, 3in center clearence, yoko geolanders
STR8_UP is offline   Reply With Quote
Old 01-14-2006, 10:30 PM   #2
Looks pretty scale. The Goelandars with the Pede fronts make an awsome scale combo. Good work!
ILoveRCRockCrawlin is offline   Reply With Quote
Old 01-14-2006, 10:40 PM   #3
I joined the Band!
thanx ^^^
_Jason
Old 01-14-2006, 10:43 PM   #4
Nice looking rig! Looks like those are pede rear wheels, not fronts.
rctruckchopshop is offline   Reply With Quote
Old 01-14-2006, 10:51 PM   #5
I joined the Band!
your right they are rears... i think i'm going to cut the outside lip off and narrow them a quarter inch...
and thanx..
_Jason
Old 01-14-2006, 10:56 PM   #6
burrlytlt's Avatar
The jeep look killer, all shinny and waiting for some thrashing.....
burrlytlt is offline   Reply With Quote
Old 01-14-2006, 11:01 PM   #7
slugzracing's Avatar
unless that is a seriously strong servo you might want to move the linkage up on the servo horn.
It looks like a fun scale toy though.
slugzracing is offline   Reply With Quote
Old 01-14-2006, 11:06 PM   #8
I joined the Band!
the reason its so far down the horn is b/c i was having trouble turning.. the truck just won't turn. i know its never going to turn tight with only a servo up front but it doesn't turn at all. so i moved the link as far down as i could and it turns better than none but still $hitty....
any ideas to make it turn better?
thanx
_Jason
Old 01-14-2006, 11:36 PM   #9
Stupid question but did you cut the bump stops?
Clod axles leave something to be desired when it comes to turning radius and without going to the aftermarket CVD axle shafts you just wont make it turn on a dime. I think you will find that on a trail it is better to have to back up numerous times and actually have a servo that turns the wheels. Just pull out the dremmel and turn the wheels to full lock and then start cutting.
Also check to make sure your steering linkage is not making contact with the gearbox.
Old 01-14-2006, 11:37 PM   #10
Nice rig man, those tires and wheels look awesome!! yea that servo is gonna get killed with the servo arm like that, how much torque does it have? and try moving your upper steering link the other side closer to the servo... I had mine like is said but it was on the other side of the gearbox...
Later,
Jake
JakeDaSnake is offline   Reply With Quote
Old 01-15-2006, 12:01 AM   #11
I joined the Band!
i cut the bump stops and when the servo isn't hooked up i move the wheels side to side and it just doesn't have the angle... so CVD's will make it turn more?
the linkage is about .5in from the case
_Jason
Old 01-15-2006, 12:03 AM   #12
I joined the Band!
Later,
Jake
the servo is a cheap-o but it turns the wheels great... and if it burns or breaks i have several more that i'll just pop in...
thanx
_Jason
Old 01-15-2006, 09:38 AM   #13
looks really scale and do u have a flex pics
rocpede is offline   Reply With Quote
Old 01-15-2006, 10:00 AM   #14
I joined the Band!
^^^ flex pics soon...
its not a flex monster :( i think its because of the 3 link... i don't know... it crawls just fine tho....
_Jason
Old 01-15-2006, 11:31 AM   #15
sweet truck. I love scale jeeps.
Cant wait to getn a pede tranny i build one of those!
4x4crawler is offline   Reply With Quote
Old 01-15-2006, 11:45 AM   #16
I joined the Band!
it doesn't take a pede tranny to build one of these...
if your going shafty you can use a pede,tc3,stealth,almost any buggy/truck tranny...
or
use clod axles like i did..
_Jason
Old 01-15-2006, 11:57 AM   #17
i got a maxx tranny butn thats in my maxx 4 link truck.
2 friends are sellin there pedes so i think ill take them both off there hands!
Old 01-15-2006, 12:11 PM   #18
TEAM MODERATOR
EeePee's Avatar
Have you noticed your front knuckles are different from each other?
One would be considered upside-down.
EeePee is offline   Reply With Quote
Old 01-15-2006, 12:21 PM   #19
Location: a place of settlement, activity, or residence.
Looks good with the rear 'Pede rims. I might order a set of Geos today after we get done crawling.
thaclodking is offline   Reply With Quote
Old 01-15-2006, 08:15 PM   #20
I joined the Band!
would that make it not turn worth a $hit?
if not i'll leave it the way it is...
thanx for tellin me about...
_Jason
