Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Meet Psycho
Old 01-16-2006, 04:06 PM   #1
Default Meet Psycho
This was my first scale crawler so let me know if you have any comments or concerns.
TLT Axles
Pede Tranny
Custom Chassis
13" wheelbase.
superman0604 is offline   Reply With Quote
Old 01-16-2006, 04:12 PM   #2
Looks pretty sweet. Whats the center of gravity like on that? And sleeve the links, it'll make it look better.
ILoveRCRockCrawlin is offline   Reply With Quote
Old 01-16-2006, 04:18 PM   #3
The COG is good since the motor and the battery are located pretty low.
I do plan on sleeving the links once my wideners get here. The tires rub on the links when I turn right now so I want to get that fixed before sleeving them.
I have a set of softer springs on the way also which will allow for more articulation.
Old 01-16-2006, 05:26 PM   #4
What wheels are you running? You might want to get some wheels with more offset.
CustomCrawler is offline   Reply With Quote
Old 01-16-2006, 05:31 PM   #5
Great start, lets see some actions pics!!!
Later,
Jake
JakeDaSnake is offline   Reply With Quote
Old 01-16-2006, 05:39 PM   #6
I have a set of wideners ordered. This should fix the rubbing problem, then I am going to sleeve the links and I will get some action shots.
Oh and by the way the tires are swamp dawgs on narrowed front pede rims.
Old 01-16-2006, 06:14 PM   #7
Team *
62PYRO's Avatar
Darn Good Start.lets See It In Action.
62PYRO is offline   Reply With Quote
Old 01-16-2006, 06:16 PM   #8
Even though you have wideners on the way, you might want to find something with more offset. Pede fronts would probably be best, seeing that they have that same design and you can paint them black.
Old 01-16-2006, 06:20 PM   #9
I believe that is what he is running...
Cubman is offline   Reply With Quote
Old 01-16-2006, 06:39 PM   #10
AKA TOKEN
ColquittCustom405's Avatar
Thumbs up
Clean setup, There're right, you should sleeve those links.
ColquittCustom405 is offline   Reply With Quote
Old 01-16-2006, 08:21 PM   #11
Well I got the links sleeved.
Still no action shots. Going to have to wait for my wideners to get here to get those.
Old 01-17-2006, 11:05 PM   #12
great looking truck.....How does the laydown tranny work for you? any tork roll?
robvbro81 is online now   Reply With Quote
