Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: WOW---another TLT buildup
Old 01-22-2008, 01:06 AM   #181
it looks awesome! what are you cutting with? scroll saw and drill press? its some pretty good work.
RCMFMaxxMan is offline   Reply With Quote
Old 01-22-2008, 01:58 AM   #182
DISTURBIN' tha PEACE's Avatar
Why so much link separation in the rear? I've always set up my upper links so that at ride hight they are level to the ground. Never had torque twist problems at all.
DISTURBIN' tha PEACE is offline   Reply With Quote
Old 01-22-2008, 07:53 AM   #183
All the drilling is by hand and I have a scroll saw and a verticle band saw.
I don't have any more than I had before. Its an illusion from the housing being rotated more (pinion up). So I might have to knock a tad off the uppers...
crash is offline   Reply With Quote
Old 01-23-2008, 11:36 PM   #184
So I finally got another batch of parts. At the last comp I heard a funny rachet noise. And then while testing--the rear end gave up.. So I ripped the rear end apart and found the side gears a lil messed up along with--all the epoxy turned to a greasy substance...
So I just cleaned the mess for now and re-epoxied it..
But I was expecting to find teeth missing off the ring gear. But rather I just found them folded over---pot metal,lol...
So this time I shimmed the pinion gear so it should last longer than a year--if not then its time for hardoned gears..
I also went and upgraded the rear shafts to these...
I am waiting for my rear lockouts so once I get those I will toss the wear knuckles/ears...
Old 01-23-2008, 11:37 PM   #185
I also got the trany disconnect linkage done..
Old 01-23-2008, 11:42 PM   #186
Since I ran the rear diff farther back than the front--the rear driveshaft had to be extended. Pretty easy really. Just used a portion of female shaft to mate the male portions.
I also finally tossed the stock tlt body mounts and went with some HPI side mounts. MUCH better
Old 01-23-2008, 11:44 PM   #187
And here is how it sits. I ran out on my lil test pile of rocks and the thing is yet again better...
So I am waiting for a couple more parts and then its ready for the comp....
Old 01-24-2008, 11:48 PM   #188
Did a little body work.. found out right away the sides of the body----no like the rocks,lol...
I am going to hopefully get the body stripped and painted by the next comp...
Old 01-28-2008, 10:23 AM   #189
I decided to go ahead and re-configure the battery packs on more time--ended up moving the 2 cells that were on the servo to the sides--triangle shape.... I also went and swapped everything over to deans plugs. Not 100% sure how the velcro will work out but I will run it and see what hapens...
Old 01-28-2008, 10:26 AM   #190
And of course--- With a new rig I needed a new body----ok I just stripped my old body(which I like) and repainted it with the same colors as my bronco body was--I like it MUCH better than the blue....
Old 01-28-2008, 01:19 PM   #191
the body repainted very nicely. whats your stripping method (hehe)
Old 01-28-2008, 02:15 PM   #192
Get this
Brake fluid
Just rub it on and let it set. It will either get soft or come off--and all I use is a wadded up ball of brake fluid soaked TP and rub on the paint--works like a champ..
And the wife wasn't even mad at me doing it in the kitchen sink
Old 01-28-2008, 03:36 PM   #193
Originally Posted by crashfab View Post
Get this
Brake fluid
sounds good! i tried oven cleaner and it sucksssss. It didn't even get the paint off at all but instead it ate at the lexan putting thousands of cracks all over it and making it brittle :( it ruined a $25 hood for my tlt tuber
Old 01-28-2008, 07:41 PM   #194
I joined the Band!
Dang dude! that looks so awesome! Im very impressed!
Crawler374 is offline   Reply With Quote
Old 01-30-2008, 12:09 AM   #195
Well I had planned on this upgrade but the timing was perfect as my ESC dropped dead..
But its the novak goat brushless setup--this should hopefully do the trick
Old 01-30-2008, 12:10 AM   #196
Thanks--I hope it does better at the comp coming up on saturday
Old 01-30-2008, 02:37 PM   #197
Oooooh Shiney!!!!
Nice upgrade Mike. I'm jealous.
NICKC is offline   Reply With Quote
Old 02-17-2008, 10:34 PM   #198
Well I decided to rip the front apart. I had found the 3 bolts that hold the diff cover on had started to come out and all of the epoxy had finally turned to mush. So I went and redid it all and shimmed the pinion. Well within 1/2 hour the front went pop. I went and ripped a couple teeth off the pinion.
Well these lil jewels finally showed up.
So I shopped around and just could not beat the price on the RCP ring/pinion combo--so I ordered up a set for the front/rear..
I tried to shim the pinion and not an option. I even tried to shim the carrier but thats a no go either--so I jjust installed them
And now the rear is about as strong as it can be...
Old 02-18-2008, 12:21 AM   #199
beefy axles
iwantoffroad is offline   Reply With Quote
Old 03-28-2008, 12:31 AM   #200
Soo--just a lil update..
I have been to 3 comps now and just love it and getting the hang of it..
Along the way I have upgraded a few things.
Went to a 7 cell 2/3a packs---man these things fit nicely on the front diff..
I also upgraded the fronts finally to CVD's and running a good steering servo (hobico cs170)
Along the way I ripped the splines out of my front RCp locker and fried my damn goat
But since I have been really beating on this thing--this thing was just done.
So it was time for a new body--the first time I saw it I just had to have it
