Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: WOW---another TLT buildup
Old 02-06-2006, 11:52 PM   #1
Default WOW---another TLT buildup--Revap to COMP rig
Ya, not another one,lol. It all started by getting my 10 year old a decently built TLT-1 for x-mass. So since I figured he had one, heck I needed one too (actually wanted a really cool RC thing since I was a kid). So I got in on ultimatehobbies sale for new years and bought a TLT-1 and have spent the last couple months slowly gathering some parts.
Here are the specs
TLT-1 Rock buster
Tekin Rebel 2 ESC
19 turn motor(55t lathe should be here in a couple days)
Stampede trans
HPI 5" shocks
Traxxas radio/reciever
2.2 masher 2k's (fronts have BB's)
Metal geared servo's front/rear
I built the links using 1/4" alumimum rod, drilling them and tapping them to 6-32 and using althread to connect the hiems
crash is offline   Reply With Quote
Old 02-07-2006, 04:14 PM   #2
nice what shocks are those?:?
gren2 is offline   Reply With Quote
Old 02-07-2006, 07:08 PM   #3
Yeah those are some pretty sick shocks. Where did you get them and how much?
ILoveRCRockCrawlin is offline   Reply With Quote
Old 02-07-2006, 08:09 PM   #4
They are HPI's
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXHSR5
Right now I am fighting bad torque twist. hit the gas and the body shoots over to one side so I am guessing the springs are too soft...
Old 02-07-2006, 11:08 PM   #5
truck looks great.........and for torque roll try a stiffer shock on the left rear!
robvbro81 is online now   Reply With Quote
Old 02-07-2006, 11:12 PM   #6
Can I change the valving in the shock itself to slow it down? The shock came with a 2 hole valve in it and it also came with a set of valves(Guess thats what you can cal them) with one hole. I am also runign 30w oil.
Old 02-07-2006, 11:24 PM   #7
Oppan Gangnam Style
chino63's Avatar
shock piston change or heavier wt oil will help, or stiffer spring. the spring might change the artic a little though if too stiff.
chino63 is offline   Reply With Quote
Old 02-08-2006, 12:50 PM   #8
changing the shock piston will work.. but you still might need a stiffer spring
Old 02-08-2006, 02:32 PM   #9
What is the actual length of the shocks???? Tower says 117 on one part and 127 on another.
dpim is offline   Reply With Quote
Old 02-08-2006, 04:16 PM   #10
are those jato or revo shafts you are using thurrrr
Tha Dawg Catcher is offline   Reply With Quote
Old 02-08-2006, 08:59 PM   #11
Ya, I do believe they are the revo shafts..
The shocks are the 117mm length ones
So I started playing with it, basically kinda driving myself mad,lol. In any case I think a part of the problem is the link geometry. With the origional way I had them you got alot of axle steer which was causing the chassis to roll to one side under load (granted yes the spring rates are not helping matters any). So now I am thinking about moving the upper mounts at the chassis to above the driveshafts(getting seperation on the chassis side) and I was also having clearance issues with the lower links to the driveshafts.
Old 02-08-2006, 09:28 PM   #12
You sure Mike? I bet they are Jato.... Revo shafts are pretty big.
A old image showing 'Pede, 2.5 Maxx & Revo shafts.... Jato shafts are almost equal in O.D. to 'Pede shafts, yet Jato shafts have a lot more splines.
toyofast is offline   Reply With Quote
Old 02-08-2006, 09:31 PM   #13
Your right (you 1)
Me wrong (me zero)
I just looked the part # up... duh---I am just gettin old,lol....
Old 02-08-2006, 09:40 PM   #14
Crash... You need to drive your butt down to Portland for the ORCRC competition on the 19th. The ORCRC Comps are mostly 2.2 based so I bet you'd be able to touch and play with everyone else's TLT.
Old 02-08-2006, 09:43 PM   #15
Thats a sunday isn't it. Dang, got a big "put up or shutup" kinda run on saturday (get to use the new front end,lol) and not sure whats going on sunday.....
Old 02-09-2006, 02:13 PM   #16
All our Comps are on Sundays. That leaves Saturdays for real wheelin'.
The ORCRC Comp schedule:
ORCRC Competition Schedule for 2006:
Scheduled Events
Feb 19, 2006 ORCRC 2
Mar 26, 2006 ORCRC 3
Apr 30, 2006 ORCRC 4
Jun 4, 2006 ORCRC 5
Jul 9, 2006 ORCRC 6
Aug 13, 2006 ORCRC 7
Sep 17, 2006 ORCRC 8
Oct 29, 2006 ORCRC 9
Dec 10, 2006 ORCRC 10
There are plenty others to try to make
Old 02-11-2006, 12:49 AM   #17
Very cool. I will write them dates down
Old 02-11-2006, 11:52 AM   #18
Scheduled Events
Jun 4, 2006 ORCRC 5
Jul 9, 2006 ORCRC 6
nice 1:1 then 1:10, wheelin' all weekend!
Unimoger is offline   Reply With Quote
Old 02-11-2006, 05:00 PM   #19
Nailed that one
Old 02-11-2006, 05:10 PM   #20
Ok so with the current configuration my upper link on one side was hitting the driveshaft plus alot of body roll that would keep the rig leaned (I know stiffer springs would help but I really didn't think that was the root problem).
So I decided to relocate the uppers on the chassis side.
It helped with some of the body roll and my link was no longer hitting the driveshaft but due to al the links being paralell it caused alot of side to side movement so I was not pleased with it at all and scrapped that setup. one thing I did notice apon looking at how the rig was reacting thru the suspension travel that both setups casued a little bit of axle steer and looking deeper into it--being as how light the rig is and the fact the axles are locked up I think alot of the body roll was being caused by the suspension loading up. I had a simular thing happen to a 1:1 rig I built (4 link/coilovers) for a guy using his specs on the suspension and (triangulated 4 link) and it had alot of axle steer when the suspension cycled and when you loaded the rig up the body would dang near shoot to one side. Off with that setup. Here is what I did.
I went ahead and left the lower links alone as they looked to be in a good location.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
