07-20-2010, 12:39 AM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: salina,ks
| tlt axles
im just wondering how good the tlt axles would be on a scaler, i plan on putting a three or four link on them so if anybody does have them if they could give me any info thanks for looking
07-20-2010, 09:36 AM | #2 |
RCC Addict Join Date: Nov 2005 Location: Utah
There are 1029381092831 scalers using tlts. They are good.
07-20-2010, 11:31 AM | #3 |
Rock Crawler Join Date: Oct 2006 Location: Fernley
I really like the TLT's for scalers. They are easier to get a good look with the tires tucked in under the body. What kind of info are you looking for? I currently have 5 scalers running the TLT's. Depending on how rough you are going to be on yours, will determine how much you need to upgrade them. I have two that are still running completely stock TLT's with the exception of bearings. I would really look into some straight axle adapters for the rear, and some aluminum knuckles for the front. If you plan on being rough with it I would also look into some aluminum C's, or have some spare axle cases on hand. RCP makes some nice axle truss'/link mounts, or it is fairly easy to make your own 4 link mounts. The third gear trick is the easiest for locking them. Also be sure to shim the gears. |
07-20-2010, 12:00 PM | #4 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
Frankly they blow and no one uses them, That is why the TLT subforum is here, so everyone can post their build threads that don't use TLT axles and how bad they suck. If you actually browsed through the TLT section, I'm sure you could answer your own question. |
07-20-2010, 01:02 PM | #5 |
alright thanks guys for the information i just wanted them for a scaler i see alot of people use the axail axles had a axail ax10 with some on there and they werent bad just wanted to use something diffrent than what everyone else is using
07-20-2010, 01:19 PM | #6 |
A little late for that, everybody and their brother was running TLT axles before Axial, and when Ultimate Hobbies was blowing em out the door at $79 bucks. RCP has CVD's and nice R&P's for em to make them bullit proof. |
07-20-2010, 04:10 PM | #7 |
| The only way i use TLT axles, is if it fits the body width, as axial axles are too wide for smaller 1/10 scale stuff.
07-20-2010, 08:18 PM | #8 |
ya want to use them for the tamiya f350 body, but it think that the tamiya uses them on there kits
07-21-2010, 10:27 PM | #9 |
hey i just found the alloy casing is that realy just for show or does that have any perpose
07-21-2010, 10:52 PM | #10 |
you could try the alloy housings but when you can just buy aluminum Cs from RCPcrawlers or Montana Scale Designs, the housings are kind of a waste of money.
07-21-2010, 11:45 PM | #11 |
I wanna be Dave Join Date: May 2006 Location: akron
07-21-2010, 11:47 PM | #12 |
07-22-2010, 01:04 AM | #13 |
