03-11-2006, 01:08 AM | #41 |
Rock Crawler Join Date: Mar 2004 Location: BAY AREA
03-11-2006, 10:27 AM | #42 |
Rock Crawler Join Date: Nov 2005 Location: Fremont/Newark, California
good job casey looks great....
03-11-2006, 11:34 AM | #43 |
RCC Addict Join Date: Dec 2004 Location: Central NY
Looks good. That tranny looks like it will help out a lot with the center of gravity.
03-11-2006, 11:40 AM | #44 | |
Oh yea... My goal was to design OUT all the problems I see with my buddies rigs.. we worked out the bugs and its better but I went after the best possible CG when designing the chassis at the cost of a somewhat bad driveline angle. The motor is about 1.5" lower than an aftermarket pede style chassis.... when holding this rig and another with an aftermarket pede tranny, your can literally feel where the weight is sitting and how much difference there is.. It will be running by the end of the day.. | |
03-11-2006, 11:48 AM | #45 |
Quarry Creeper Join Date: Dec 2004
looks great dude. couple of things.... the upper link mounting at the chassis. Your rod ends' travel is alradey maxed out. That's going to cause binding. You can counter that a little by putting the links on the inside of the chassis with misalignmnet spacers. But the problem I see with that (and believe I know why you mounted it like that) is to clear the diameter of those Revo shafts..... Shock mounting at the axles. I would try to have the shocks at the axle mounted as far apart as far as possible (check clearances at full lock left/right). This will help fight torque twist. Gearing 90/11 with that tranny is really low. Especially if your using a lathe motor with a 6 cell pack. You will have no wheelspeed. I'm running 87/12 with a 45T lathe, you've seen the speed of my rig.... be a shame to cover up that work with a body! |
03-11-2006, 11:52 AM | #46 |
Yea I see the issue with the links at the chassis.. So I think I am going to mill a chamfer there and mount the link at perpendicular beveled edge.. if that makes sence.. I know it looks bad, but it isnt causing any issues at this point, but onthe rocks is a different story.. thanks for the imput..!~ |
03-11-2006, 11:54 AM | #47 | |
Mounting the upper links inside of the TVPs reduces the triangulation effect of the links...good to keep them outside of the TVPs as they are now, if possible. I agree on the shock mounting and the motor/gearing. However, not everybody runs the narrowed wheels and axle spacers that you have on at the moment...keep that in mind...also shocks too far apart will limit travel, but may not matter as too much travel is not good either. Last edited by Natedog; 03-11-2006 at 12:00 PM. | |
03-11-2006, 07:03 PM | #48 |
Pebble Pounder Join Date: Feb 2005 Location: HAWAII
ive been waitng for a chassis like this keep us posted (pics) **maybe a vid ** too . also will u be making a kit ? wat would u include in the kit . cuz i got a pair of tlt axles and a stealth tranny for a rc10t3 waiting to be transformed into a crawler. so keep us posted and good luck with the truck. btw awsom truck!!!!!!!!!!
03-11-2006, 07:36 PM | #49 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
Crazy man! Bada$$!
03-11-2006, 10:21 PM | #50 | |
Well any issues we thought would come from the shafts should be put to rest as they survived a good thrash.. Its smooth as silk with these shafts.. There is NO such think as torque twist..! We dont even see it twist a hair.. It does sit very low and makes alot of high centering but with the slickness of the delrin, once a tire touches it jumps and slides right over.. I deffinatly need a little more articulation.. or weight in the tires... or softer springs.. Well I guess I need to play with it some more.. I got an hour out of my pack.. The 55 turn isnt impresive, and I hope the 35 turn is here on monday.. *cough*cough*.....! So far I am very impressed.. I think I will get rid of the jerry rig wire job I through together to run it as I was iching like crazy... and hopfully tommorrow we can get a real world test other than what I am working with at the house.. Quote:
Once I get it dailed in more I will have vids all day long.. Thanks for the kind words and support..! Last edited by skipstr71; 03-11-2006 at 10:55 PM. | |
03-12-2006, 12:00 AM | #51 |
good news hope u can work out wat ever bugs u need, and thats swwet about the steath spool for revo shafts ill defiantly buy the spool . and if u do end up producing this kit will it be availiable in derlin chassis, is derlin rigid enuf and kight enuff? can i get som articulation shots
03-12-2006, 12:01 AM | #52 |
wat kit did u steal the steath tranny from cuz it looks like a b4/t4 tranny, will the t3 tranny work with this kit?
03-12-2006, 09:35 AM | #53 |
RCC Addict Join Date: Sep 2005 Location: Lehi
Man, you make some awesome stuff, skipstr!!! Great job!!!
03-12-2006, 02:56 PM | #54 | |
Yea the spool with maxx outdrives is the key to this build.. Its what makes a stealth a crawler tranny IMO.. Oh yes I belive the delrin is plenty beefy. Take a look at the ultra nie bender 23mm adapter.. they are made from delrin.. This is an older tranny that I got in a box of parts... I have the newer style tranny and those are the ones I am working to get a dozon of.. I will base the production chassis off of these.. Here are some articulation shots. I never really liked the maxx shocks. I traded them out for a taller twin force shock. These are way smoother and about 3/8" longer. That gave me the articulation I was looking for. The shock body just touches the link at full twist. First 10 min of run on it seems even better. Still no drive shaft issues and I even had a brain fart and didnt set screw the shafts to the yokes and it still survived all last night and today.. I am so very impressed with this and think its gonna be something... Machined on the pinion and the revos shaft for a solid fit. Its not perfected and I want to make a real adapter for it but for now its holding up without a problem.. Almost huh.. | |
03-12-2006, 03:07 PM | #55 | |
Where did you find a 11 tooth 48 pitch pinion at? Lowest 48 pitch pinion I have found is a 12 tooth. | |
03-12-2006, 03:23 PM | #56 | |
Hobby town here in fremont.. It is a RRP product... They had lower but HD took it I belive... But it was too low so its at 18/90 at the moment.. | |
03-12-2006, 03:50 PM | #57 | |
Techinicaly its a spool that has maxx outdrive yokes that replaces the diff in the stealth... But this tranny is unbeliveable strong. Halfcab runs it in his full size crawler with a brushless on it and its handles it without issues.. So I know how strong these trannys are, and belive it will eliminate the goofy pede tranny... | |
03-12-2006, 04:00 PM | #58 |
a WAG (Wild A$$ Guess) is $25
03-12-2006, 04:27 PM | #59 | |
Robinson Racing must not have it listed on there site then, lowest they show is 12 tooth: http://www.robinsonracing.com/catalo...tchpinion.html | |
03-12-2006, 07:17 PM | #60 |
Toyfast... If you want one bad enough, I'll dig through the trash and get the part #.. I am not even using it as its way to low for my set up... Got the LiPo battery and she weighed in just under 4.5lb (with lipo) loaded and ready to crawl.. Charging up the LiPo and finalizing the wiring on it.. |
