08-26-2010, 08:24 AM | #1 |
Rock Stacker Join Date: Aug 2010 Location: Toronto, ON, Canada
| Stock TLT-1 - first items to crawl?
Hello all, I have a 100% stock TLT-1 Max Climber with a 3 channel radio (with rear steer). Now I am considering to turn it into a crawler. What would be the first recommended mod? ( I want to go step by step). I know many things can be done - but what has the biggest impact, while being relatively cost effective to do? My ESC is a non crawling one, and the motor is relatively fast: should I start with those? If yes, what (low cost) options would I have? Thank you all! |
08-26-2010, 10:29 AM | #2 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
The chassis if still runing the stock one, It has no ground clearance. Lengthen it...........ditch the tranny for something better(i.e. no belt) |
08-26-2010, 12:37 PM | #3 |
08-26-2010, 11:25 PM | #4 | |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
Chassis, there are many that will wor with TLT axles, most AX10 chassis can be used or modified to use with the TLT, most were initially designed for the TLT anyways. You can pick an older Bender SW2 or SW3 pretty cheap, they work with a Stampede tranny or AX10 tranny. I would suggest the AX10 tranny and get a dig setup for it, like the VP Hurtz Dig. Use the 3rd channel for this Pick up some new links to get your wheel base out to 12.3"-12.5", new servo mounts/battery trays with 4-link mounts are availble from TCS, RPP and a few others. Lock the axle diffs, either by buying a locker, or by locking the stock one. I always prefered adding an extra gear backwards in the diff housing to lock it, but there is always JB weld.... Invest in some MIP CVD's., Axle C's w/high clearance knuckles and straight axle adapters for the rear. Get some new 3.5"-4" Shocks, the stockers are more suited to scale rig builds. Some good 2.2" beadlock rims and some good 2.2 tires. Then start experimenting, I know I am missing some stuff, but have the fun is discovering it for yourself!! Welcome to the addiction!! Here's some pics: I still beat most people in sportsman with this rig, and nothing on it has changed since 2007 except the body was replaced!! SW2 SW3 More TLT Builds and Ideas: http://s732.photobucket.com/albums/w.../TLT%20Builds/ Last edited by PaloAltoK5; 08-27-2010 at 12:07 AM. | |
08-27-2010, 06:47 AM | #5 |
Thank you for all the great suggestions. Time to do some more focused research and then start building...
08-27-2010, 04:49 PM | #6 |
Quarry Creeper Join Date: Jun 2010 Location: Marsing ID
or if you want to go fairly cheaply & not have to buile/experment, there is roler with a bender chassis, etc on RCuniverse for $150 http://www.rcuniverse.com/market/item.cfm?itemId=667183 wish i had gone that way.... Im into mine close to 250 & still need a better motor, different links & mounts. |
08-28-2010, 08:37 AM | #7 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
I've been running TLT's for years, still have 5 rigs running their axles. First thing to get is a plan on what you want to build. Do you want to build a comp style crawler or a scale crawler? Then decide on a chassis. I've been using the Reign K2 designs for some time. If you can find a used K2-5 (the last generation) you can build it either way. I used one for a comp chassis at full length and took 3 third on a comp course with it. It worked amazingly well. Then built a scaler with it. It's a very versitile chassis. Building a scaler will also keep the cost down because you won't "need" to beef up the axles as much due to the smaller tires. Good luck with what ever you build. I've added a few pics of my rigs to show how versitile the axles can be. This was my first scaler built in 2004(back in the day scalers were 2.2 rigs) His name is Ralph. I miss this thing, maybe I'll build his cousin Henry someday This is Mugsy my tube comp chassis, works better than pretty much any tube chassis I know of. Built in 2006 The Shop Truck is a old Tamiya Mountaineer chassis running a stampede tranny and good ol TLT axles with leaf sprung suspension. This is my Jeep Cherokee scaler, running the Reign K2-3L chassis modified for more ground clearence and narrowed for better shock mounting. None of these rigs run any wideners, stay away from them. In my opinion the best way to change the track width is by tire & wheel choice. Most of the 2.2 rigs were between 10-10.5" and the scalers are 8.5" wide. enjoy the addiction |
