03-30-2006, 09:03 AM | #41 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
OK this is reworked again. This will take .58" off the bottom and flatten the belly I may in the end give it a slight curve but not much maybe .08" added curve to the center area. Like I said not much. |
03-30-2006, 11:39 AM | #42 |
Gold Star Baby Momma! Join Date: Feb 2004 Location: Maumelle, Ar
That looks real good, Double J, I like all the options you have with all those holes. Maybe a rename is in order?...................Vertical Swiss cheese!!! When is my new design chassis coming.......................................j/k Kevin |
04-02-2006, 10:28 AM | #43 |
HELLo?
04-02-2006, 11:20 AM | #44 |
Rock Crawler Join Date: Mar 2004 Location: Albany
Hey Tuufguy have you thought about running the stock TLT standoffs I believe they are 2" instead of the 3" ones that came with the chassis. That might help your truck abit not having the super wide chassis.
04-02-2006, 07:32 PM | #45 |
Now that is an idea, thanks. I am on vacation this week so, you know what that means!!!!Cheetos and building time! Kevin |
04-03-2006, 01:43 PM | #46 |
Have you found any other problems with the chassis?
04-03-2006, 08:44 PM | #47 |
No other problems to speak of other than the width, just a little wide for tlt's. I was going to use the tlt standoffs that manicmagoo suggested but I am too lazy. But, I did something to the chassis, see if you can spot it. cardboard cookie to the first one who gets it right. Kevin |
04-03-2006, 08:47 PM | #48 |
Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
You drilled a hole in the center of the bottom of the chassis plate.
04-03-2006, 08:48 PM | #49 |
You also shaved some off of the bottom.
04-03-2006, 09:00 PM | #50 |
Wasn't really talking bout the hole in the center but you are right. shaved, or "TUMMY TUCKED" the middle as the "cool" nylint kids say Made a world of difference, I also ditched the tranny mount and use some 1/4 delrin as a skid, lowered the tranny. It changed the breakover alot, alot more than I thought it would I will add delrin to fill in the back half if I see a need. (already have it cut) It really slids over the rocks now. Kevin |
04-03-2006, 09:50 PM | #51 |
And I didn't even need to send another test chassis out to you. Well that is what the official Chassis will look like. I will have a little bit of a round to the bottom but as mentioned before verry little. I've been looking for a place to buy derlin local any thoughts on places to look? |
04-03-2006, 09:52 PM | #52 |
I'm telling you try the stand offs it will be a completely different truck.
04-07-2006, 09:22 PM | #53 |
I have made all necessary adjustments to the chassis thanks to all of the testers input. They will be available in about a week. The first 4 to order will get it for $40.oo |
04-07-2006, 10:26 PM | #54 |
Rock Crawler Join Date: Jan 2006 Location: Dallas
nice looks good nice looking bronco too!
04-09-2006, 09:50 AM | #55 |
Thanks I found some locally that will cut it to size and the price is good also. It's also a thicker than the 1/4" on ebay, and cheaper than the ebay one. I appreciate the info though. Nice to have someone look for me. |
04-09-2006, 10:28 AM | #56 |
Hey double, if you use thicker than 1/4 inch that is going to raise the tranny and motor up more which is not good, the stuff I am using is 1/2 inch and I think it is too thick. You don't need it to be thick with how your chassis is built, Imo. Just my .02 Kevin |
04-11-2006, 03:00 PM | #57 |
I't wont be quite 1/2" it will be 3/8". That will be thick enough to mount the chassis to it and use it as a skid, then sand or bevel the edges to match the chassis sence it has a slight curve to it. Should work well. I probably cut a little more off the bottom than you have on yours and moved the mounting holes to keep the chassis at a low CG. This will be very adjustable to suit the needs of those who will purchase it. And as a side note I still have 2 avaible at the discounted price. They will be ready to ship by this weekend (4/14/06). |
