| | #1 |
| Newbie Join Date: Sep 2005 Location: Cut -N- Shoot, Texas
| Last night I was messing around with my new Stampede diff trying to figure out a way to lock it. Here is what I have come up with........ Parts/tools 12 - 3mm washers(part# BC6 in screw bag C from tlt kit Stampede diff parts of course 5/16 drill bit ![]() First put a pin with 3 of the 3mm washers in one of the holes in the diff plate/cover without the nub. ![]() Next take the 5/16 drill bit and by hand twist the bit and shave the nub down until it is the same height as the pin with the 3 washers. ![]() At this point you should be able to place the gears that go on the pins and they should be at the same height. Repeat the same process to the other side of the diff plate and inside the main diff gear. ![]() Now you should be able to start assembling the gears and pins with the washers in proper place. ![]() ![]() It should look like this now before you put it all together. ![]() I have not tested it in a working rig but I did put an allen wrench in one of the output shaft holes and turned the spur gear by hand and I was teaking/bending the allen wrench. Basically I'm just shimming the gears so they are all binding together. So I think it should hold up. Oh and no epoxy needed. Last edited by fatrat496; 03-31-2006 at 10:15 AM. |
| Sponsored Links | |
| | #2 |
| 1 man, 2 sons ![]() Join Date: Aug 2005 Location: Recovering@ the hobby garage MT.
| wow, that is a neat idea, I will be interested to see how it holds up in the truck when you pound on it! |
| | #3 |
| Hopefully nothing happens when I pound on it |
| | #4 |
| Newbie Join Date: Jan 2005
| You can lock the stampede diff even easier than that. All you need to do is open the diff up and take out the two planetry gears that sit the lowest in the diff. Then you take two 3mm nuts and put one under each lower planetry gear so that all the planetry gears sit at the same height. Then you file down the two little raised sections on the top diff case and screw it back together. ![]() ![]() ![]() Jon |
| | #5 | |
Did you file down the the raised sections inside the main diff? I just tried to make sure I did everything I could so that the planetary gears were in the center and that all 4 planets were touching the output shaft gears the same amount. | |
| | #6 |
| If you look at the pictures then that is exactly how i did it. Just file the raised bits on the cover of the diff |
| | #7 |
| Rock Crawler Join Date: Jan 2007 Location: San Clemente, CA.
| Thanks for the info I will be doing this shortly and wondering what I was gonna get into, the search button rocks |
| Thread Tools | |
| Display Modes | |
