Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Were to get useful leaf springs?
Old 03-31-2006, 08:51 PM   #1
Default Were to get useful leaf springs?
I would like to use leaf springs in my next build. Were do I get ones that are not to stiff? Also can I get them with the shackles? Other than the Bruiser what trucks have come with them? I was told that the Juggernaut did but that those are to stiff, is this true?
tkruger is offline   Reply With Quote
Old 03-31-2006, 10:16 PM   #2
Pretty much all the leafs on tamiya trucks are the same. And I think they where the only ones to use them. Yes the leafs are stiff but I found after I ran mine for a bit they did flex alot more than I thought they would.
All that being said, I'm pretty new to this hobby so........:?
madhatter is offline   Reply With Quote
Old 03-31-2006, 10:22 PM   #3
Haters gonna Hate
1BadJeepBruiser's Avatar
Best bet is to get some juggys and remove all the leafs but the main leaf, thats what I am doing on my Trekker, its still a tid bit stiff but I am hoping they will work better once there is some wieght in the truck
Mike
Old 03-31-2006, 10:41 PM   #4
Colt Python/SR9c
TwistedCreations's Avatar
I can't tell you much about the springs, but I seen that Gardentrucking.com has some springs also.. Not sure if they are still as stiff as juggy springs or if they are ven as long as them. I just came across them today..
http://www.gardentrucking.com/produc...x=5&startAt=16
they are in the 16-20 range
TwistedCreations is offline   Reply With Quote
Old 03-31-2006, 11:33 PM   #5
I'm not sure about stainless leafs :? I've worked with stainless lots over the years and it doesn't strike me as haveing any memory when it comes to flex. I think they might be more show than go.:?
