| | #1 |
| Rock Crawler Join Date: Sep 2005 Location: wyckoff, NJ
| So I built your average SW2 and it does awsome and all. Right now from outside of tire to outside of tire i'm at 9.75, now is it worth getting wideners? I know alot of guys run them, but does it really help? I would get the ones the crawler store sells. Thanks for your opinions. |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Feb 2005 Location: HAWAII
| there r pro's and con's tp wideners............. it helps stability on off camber crawls but wider axles seems to getr snagged more often. i run wideners becuz my chassis ( jefferson) requires it for shock and tire clearance. |
| | #3 |
| Rock Crawler ![]() Join Date: Aug 2005 Location: lititz
| I run widners on both of my sw2's. thunder techs on the one and gmades on the other. I personally like them for the added stability in off camber sitiations. matt |
| | #4 |
| Rock Crawler ![]() Join Date: Jan 2006 Location: Tennessee
| i have wideners on my sw2, it does great with them. so go for it. |
| | #5 |
| RCC Addict Join Date: Mar 2006 Location: MUSE, PA
| i run the tobee craft 32 mm wideners on my sw2, i think they work really well, and of all the wheel wideners out there, i feel that these are the best looking/made ones on the market... |
| | #6 |
| RCC Addict Join Date: Dec 2004 Location: Central NY
| Well like said before, there are pros and cons. They help a lot with stability. But they also put a greater strain on your servo. So if you're running something under a 645mg hitec, then you might want to get a 645mg or something similar, depends on the brand you prefer. |
| | #7 |
| I've got a hitec 645. |
| | #8 |
| So i'm looking at Tobee Craft wideners on ebay and like how its the whole axle stub piece but when it says "48mm" does that mean per side? Which would be the closest to the crawler stores widener width? |
| | #9 | |
| | #10 |
| RCC Addict Join Date: Jul 2004 Location: The other Crawler State
| I am going to run without wideners this time, they seen to break axle housings. I figured I would have to adjust my driving accordingly, but the new truck is low too. |
| | #11 | |
Really what ever gets you 10"-10.5" should be fine. | |
| | #12 |
| Mayor of Bedrock ![]() Join Date: Feb 2006 Location: 1st and Amistad
| I'm also running an SW2 at 9-3/4" and thinking about wideners? After reading this thread, I'm still undecided. lol |
| | #13 | |
| | #14 |
| RIP Buster ![]() ![]() ![]() Join Date: Mar 2004 Location: Norcal
| I have never ran wideners on any of my TLT's. Probably never will. |
| | #15 | |
| 1 man, 2 sons ![]() Join Date: Aug 2005 Location: Recovering@ the hobby garage MT.
| | #16 |
| So what do you guys think is stronger, a long axle stub or a short axle stub with an extenstion? |
| | #17 |
| RCC Addict Join Date: Apr 2004 Location: Santa Clara
| I can only speak for going non-widened for that is all I have ran. I think my rigs have side hilled with widened rigs quite fairly. I have never measured, but so far, I am happy with the narrower track. I'd say, if you are competing, try to get the narrower stance to work to edge out a little extra clearance between cones. At least just leave your rear narrowed anyway since it is non-steering. Just my suggestion. I will most likely not go any wider than stock width axles. -Sam |
| | #18 |
| i got the tobbee craft 32mm wheel wideners and it widened the axles with masher 2k (unarrowered rims) from 10" to 11 1/4" , the 32mm doesnt add 32mm to each side its adds 16mm to each side. (half of 32) when i runthem ill let u guys know how i like them |
| | #19 | |
| | #20 | |
| Thread Tools | |
| Display Modes | |
