Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: got my tlt done
Old 04-09-2006, 09:53 PM   #1
Default got my tlt done
bender chasis and link mounts
55T lathe
TR2
TQ3 setup
Moabs
Gmade wideners
Duratrax Evader shocks
hitec 645 servo
87/12 gears
and an old FXT stadium racer body hacked to hell and sprayed john deere green. will have a pic or 2 up tommorow
took it out for first time today. serious torque flex on steep inclines. that right front just wants to come up, cant keep it planted. gonnt try bb's. broke a front inner shaft, and im havin trouble keepin driveshafts on it.
diablo0072k is offline   Reply With Quote
Old 04-09-2006, 10:43 PM   #2
2006 2.2 National Champ
BENDER's Avatar
What springs/oil are you running in the rear? I use 10wt oil in the 2 front shocks, with Losi white springs. I run 20wt oil in the right rear shock and 35wt oil in the left rear shock, both running Traxxas black Stampede springs. I barely have any torque twist.
What driveshafts are you running? Did you drill the axles pinion shafts?
Post some pics, so we can see your set-up.
BENDER is offline   Reply With Quote
Old 04-12-2006, 09:26 PM   #3
im runnin the duratrax yellow springs on all 4 corners, i have a set of whites, but there almost too soft. im gonna go to the lhs tommorow and get some shock oil.
