Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: New SW2 TLT Comp rig
Old 04-12-2006, 05:38 PM   #1
RIP Buster
badger's Avatar
Default New SW2 TLT Comp rig
Nothing fancy, just another SW2 comp crawler with a slightly different link setup. I built this truck in one night (until 4:00 am) before the last comp, only to break 2 axle shafts in less then 3 minutes of running.
Here are the specs:
12.5" WB
10" track width
2.5" center clearance
~8.5" max height of cab
Bender Customs chassis set up 70/30 (almost 75/25)
Custom Carbon Fiber Links
TLT-1 Axles locked diffs
Stampede trany w/Jato shafts, 120T 64P spur
55t Lathe Motor, 16t 64P pinion
Proline Moab tires
Pede rims double narrowed w/rock rings
2 wheel steering
Traxxax big bore shocks
Jeep CJ8 body off my TXT, then Clod (this body is nearly 2 years old with a history of abuse)
4 oz of bb's in each tire
Futaba 3ch 72 Mhz FM receiver
Airtronics 94359 Servo
Spare maxx drive shaft and Tamiya wrench on the body
Working on a few additions before the next comp, the body will also be lowered about 1/4" to 1/2".
badger is offline   Reply With Quote
Old 04-12-2006, 05:54 PM   #2
1 man, 2 sons
Unimoger's Avatar
body looks beat, just the way I like them! nice work, can't wait to kick your azz in 3 weeks with mine.
Unimoger is offline   Reply With Quote
Old 04-12-2006, 05:55 PM   #3
CSR
The ol' green CJ lives on! Nice little rig!
CSR is offline   Reply With Quote
Old 04-12-2006, 05:57 PM   #4
Ultimate RC Decals
BOWTIE's Avatar
nice!!
how's the flex up front with the short links?
BOWTIE is offline   Reply With Quote
Old 04-12-2006, 06:04 PM   #5
RIP Buster
badger's Avatar
Originally Posted by BOWTIE
nice!!
Not as good as the rear. I'll take a flex shot of the front tonight.
I am not fond of massive flex on my figs.
Old 04-12-2006, 06:17 PM   #6
yukon635's Avatar
I like it. damn you have put that cj through some hell. do you find that it performs better with the 70/30 instead of a 50/50.
yukon635 is online now   Reply With Quote
Old 04-12-2006, 06:20 PM   #7
RIP Buster
badger's Avatar
Not sure about the 70/30 yet since I have about 2 or 3 minutes of run time on this rig, I do think a 60/40 setup is better then a 50/50. I think the 70/30 should perform great.
Old 04-12-2006, 07:24 PM   #8
That's a nice rig badger, Is this the comp rig you mentioned when I last talked to you?
70/30 setup makes it look very proportional with that hacked up body.
bigred is offline   Reply With Quote
Old 04-12-2006, 08:07 PM   #9
3CRacing
Knytemare's Avatar
Gah! Another truck already?!?! I gotta get weekends off so I can at least get some run time on my rig.
Knytemare is online now   Reply With Quote
