03-10-2011, 04:52 PM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: Raaaaaiiiiinnnnniiiieeeerrrr
| TLT alum C bearing mod???
my aluminum c's are totally worn out where the screws go into the knuckle. I know of the mod where you drill the c out and put a flanged or hat bearing top and bottom of the knuckle. does anyone know where to get the bearings? I know the inside needs to be 3mm. let me know, thanks. |
03-10-2011, 11:00 PM | #2 |
Newbie Join Date: Feb 2008 Location: Great Britain
My new C's are loose causing steering flop, I'm going to install Oilite bushes or turn myself a set of Delrin bushes. Mine sound like a different design to yours, my screws bottom out on the Knuckle with the head of the screw running in the C. I can get oilite bushes in the UK from almost any bearing supplier, I Googled Oilite USA and got:- Beemer Precision, Inc., Fort Washington, Pennsylvania, USA |
03-11-2011, 12:11 AM | #3 |
the bearings i used in the past were for some kind of team associated car. they were 5/16" od then the shoulder was probably 1/8" larger. i dont have a part number sorry.
03-17-2011, 02:41 AM | #4 |
update. ok i found the bearings at 3 racing. they are 3mm x 6mm x 2.5mm flanged bearing. one axle repair will take 4 of them. when they come in the mail I will do a write up with pics. |
04-05-2011, 06:25 PM | #5 |
So I found out my camera doesnt take small detailed close-up pics well. this is super easy. I just used a 15/64th drill bit which puts the hole at 5.95mm of an opening. This causes the bearing to have a press fit into the hole. I just drilled the opening and just pressed the 3mm x 6mm x 2.5mm flanged bearing in with a pair of lineman pliers on the outside of the knuckles. then I installed the knuckles with some locktight on the longer screws. works great. I got the bearings from 3racing. 10 bearings for 12bucks. warning they ship from china so it takes a few weeks to get them. sorry for the crappy pics. drilled out hole. installing bearing, it just presses in. all installed Last edited by wheelinjp; 04-06-2011 at 12:08 AM. |
04-14-2011, 11:33 AM | #6 |
