06-19-2006, 05:10 PM | #61 | |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
06-20-2006, 12:48 AM | #62 |
Rock Crawler Join Date: Jan 2006 Location: Derbyshire UK
I Spent Two Huors Last Night Trying To Fit The Gpm Knuckles, They Still Wont Line Up Correctly, I Have Asked For A Refund!!
06-20-2006, 04:50 AM | #63 | |
06-20-2006, 11:13 AM | #64 |
Thanks for your help ,I have been in touch with asia tees ,they seem to think they may have been packaged wrong, when I fit one of the 2 knuckle king pin screws the 2nd one doesnt line up, it will line up and go in if i push the knuckle fowards or backwards but then the drive cup binds and the knuckle is tight to steer, JOHN,
06-20-2006, 03:15 PM | #65 |
Newbie Join Date: Jun 2006 Location: A2
Still waiting for mine to get here... RCMART takes a while I guess. Its been 12 days so far... |
06-21-2006, 12:15 AM | #66 | |
06-21-2006, 03:10 AM | #67 |
I ordered my servo's from RCMART and they came in less then 14 days. Someone needs to post some pic's of these TA-05 knuckles on a TLT.
06-21-2006, 08:34 PM | #68 |
06-21-2006, 09:34 PM | #69 |
Rock Crawler Join Date: Jul 2005 Location: Central Coast
I just ordered a couple sets aswell. Good to know these are working
06-21-2006, 09:46 PM | #70 |
Rock Stacker Join Date: Nov 2005 Location: Perth, Australia
I just ordered 2 more pairs for my tuber project ;)
06-22-2006, 10:18 AM | #71 |
Rock Stacker Join Date: Apr 2006 Location: USA
Got mine today from rcMart! BUT, I got a pair in silver and a pair in gunmetal!! They don't match!! I guess I will put the gunmetal one in the back then.. ARGH!! I know it does not affect the function or anything, but still, I'd prefer them having the same color.. Will try them out tonight to see if they indeed fit the TLT! (these are the TopCAD TA05 knuckles) |
06-22-2006, 01:12 PM | #72 |
Do they seem to turn all the way? Or does there need to be some trimming done? Lets see some more angles of them.
06-22-2006, 03:45 PM | #73 |
They seem to turn well....
06-22-2006, 05:06 PM | #74 |
Newbie Join Date: Nov 2005 Location: Hayden
Tamiya shows the TLT-1 hubs are TA04 hubs. If you look on the back page of the TLT-1 manual, under parts code you'll find part #50867 TA04 C parts (Front Upright) (C1 & C2, 1 PC.)
06-23-2006, 08:41 AM | #75 |
Got my aluminum knuckles last night and they seems to fit the axle fine.. I do find that it seems to push the outdrive inward a little bit so you don't turn as much.. while I don't know if it is necessary to be turning that much, I am just saying that compare to stock steering knuckles, the TopCAD TA05 knuckles does not turn as much.. (slightly) Also, when mounted, it seems to take more effort to turn.. I wonder if it is because now you can tighten the screw more now (as now you are screwing into an aluminum pieces, instead of plastic, where you can't really tighten it too much without stripping) or maybe the machining on the knuckles is slightly off (almost if the 2 holes are not perfectly straight that's causing a slight binding?) It will turn, but I just think it requires extra effort.. so I need to play with it somemore to make it fit well.. |
06-23-2006, 05:31 PM | #76 | |
06-23-2006, 08:52 PM | #77 | |
06-23-2006, 09:38 PM | #78 |
Quarry Creeper Join Date: Dec 2004
TLT, TA04, and TA05 all use the same knuckle.
06-24-2006, 12:21 AM | #79 |
Pebble Pounder Join Date: May 2006 Location: San Tan Valley, AZ
Well, add me to the list. I orderd 2 pair.
06-24-2006, 08:12 PM | #80 |
Rock Stacker Join Date: Dec 2005 Location: crestwood
me too ,sweet can any of you guys that have them tell us how they are holding up.
