05-25-2006, 08:17 AM | #1 |
Pebble Pounder Join Date: Aug 2004 Location: Vienna
| To hack or not to hack?
I have a Proline Rock Pleazer body with fender lip remaining for looks. I was thinking of lowering the body substantially and opening the fender wells which will require cutting into the top of the hood and rear bed area. It may not look as realistic, but I was hoping to lower the center of gravity. Will this actually help with the lower the center of gravity or probably not notice any changes? Tech specs on rig, may help with above answer: custom chassis with vertical tranny mount (looking into custom laydown chassis design), G-Made wideners, 5 cell pack on front axle, single narrowed Proline Aggressors wheels. |
05-25-2006, 08:23 AM | #2 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
I was sceptical about how much slamming the body would effect COG as well... I can say it does seem to make a difference! More importantly... at least to me, the truck fits through cracks when in extreme off camber situations alot easier. Instead of trying to go up and over a crack you can get sideways and squeak through. That make sense to you?
05-25-2006, 11:12 AM | #3 |
dezfan, not a crowd pleazer; I have a Rock Pleazer.
05-25-2006, 11:14 AM | #4 |
RCC Addict Join Date: Jul 2005 Location: Provo
| so your saying your gona chop the fenders? |
05-25-2006, 11:25 AM | #5 |
I say just cut the **** up and slam it.
05-25-2006, 11:27 AM | #6 |
If you lower it enough, you might not have to hack anything. Once the tires come in contact with the body, and spin a little, they go past the point of contact and continue through their travel. But I mean mounted LOW! This is an untrimmed T4 Proline something or another... |
05-25-2006, 12:19 PM | #7 |
Currently my Rock Pleazer is trimmed just like Got Rocks. I was thinking of lower the body about an 1". Then this would create a load of tire rub because I currently have some minimal rub. So the idea, if it is worth it, would be to continue the fender well arc up and eventually remove the top edge of the hood and rear bed. Side note: why are pictures of Crowd Pleazers being posted instead of Rock Pleazers? |
05-25-2006, 12:33 PM | #8 |
I think it's more along the lines of Rock Pleazers suck. |
05-25-2006, 12:34 PM | #9 |
Oh and, it doesn't matter what body it is, I was saying that if you go low enough, you might not have to hack anything.
05-25-2006, 01:01 PM | #10 | |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
