06-05-2006, 01:23 AM | #1 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
| Stick style, TLT build up
I got the axles ordered up here is the plan. Go with a stick style build up. I'm not exactly sure how this is going to work with the torque twist. However, with the rotating design of the stick I'm sure I can lock most of it out with the rear shock. It's just the front I'm a little worried about. However, the advantage of unsprung weight should help. Oh well, only one way to find out if this design will work properly. Build up: Stealth Trans Maxx drive shafts Behind the axle steering 2 short shocks Delrin skid and links Masher 2k tires 55t and esc or Mamba Revolver setup Parma c10 body 4 steer or front burn Buildup sketches coming soon |
06-05-2006, 08:46 AM | #2 |
RCC Addict Join Date: Jun 2004 Location: Bruiser Heaven!!!!
here is a link to TC building a stick shafty i think and i hope this will help rich Something different 2.2 Maxx |
06-05-2006, 09:00 AM | #3 | |
actually, Sean " hackster " of ORCRC.com has already built one. | |
06-05-2006, 10:29 AM | #4 |
Pebble Pounder Join Date: May 2005 Location: United States Of America
Will Jim be aiding in the build of this build - up ?
06-05-2006, 08:53 PM | #5 | |
Rock Crawler Join Date: Jan 2005 Location: Tumwater
06-05-2006, 10:12 PM | #6 |
Pebble Pounder Join Date: May 2006 Location: Scottsdale
that sounds like a sweeeeet idea. Ever since I saw that stick chassis from thecrawlerstore I always wanted one, we need some pics man!
06-05-2006, 10:38 PM | #7 | |
06-05-2006, 11:28 PM | #8 | |
Again, truely sorry I am usually so well behaved I dont know what came over me. Chad- | |
06-06-2006, 02:12 PM | #9 | |
Newbs... | |
06-07-2006, 02:04 PM | #10 |
I'm deciding how I should go about building this rig. My original plan was to build a tub style chassis to house the trans. But, I can't really see and great advantage as compared to a normal 4link. Plus I don't know that I could make the tub chassis rigid enough to reduce twisting. I could use a stick but the trans would have to hang below or way above. Now I've got a wild idea to mount the trans up side down on top of the front axle. I'm thinking for better balance and COG. Then running the trans output to a small transfer case up high in the chassis. Doing so would allow the motor and gearbox to rest on the front axle and I could run the drive shafts really high for clearance without screwing with the COG to much. I could also make the chassis just be a tube like a stick. However, I would be adding the weight of the tiny transfer case and driveshaft to the chassis. So I don't know that there would be any advantage at all. The weight would be about equal with the batterys in back and the motor/gearbox in front. I could use wheel weights to change the balence up a little. I still don't have my axles yet but when I do I can start mocking things up, to see if this idea will work. |
06-07-2006, 08:44 PM | #11 |
Your "IDEA" of putting the motor on the front axle works extreeeemly well on my spec txt nn. A picture is in the float st thread if you want to check it out.
06-09-2006, 07:42 PM | #12 |
Axles and and stuff from Tower came today. I'm almost considering this setup. Not exactly like this, the motor maybe rotated up a little. But, it is hard to mock this up for pics. I would have to connect the motor to the front axle with brackets. Which would allow for zero torque twist up front. I could lock the twist out with the stick style suspension in the rear. The only disadvantage I see is the front driveshafts clearance is reduced. The rear shaft would need a carrier bearing. Since the shaft is so spread out for the back it would allow me to possibly create some kind of rear disconnect for front dig. I could also run the rear shaft at about any angle possible to gain rear clearance. |
06-09-2006, 08:17 PM | #13 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
06-09-2006, 09:49 PM | #14 |
79.99 Shipped to my door for the axles. Bearings $20.50 Traxxas rod ends $3.50 Maxx outdrives I stole from a friend when he upgraded to CVD's Got the Trans from ebay about 3 years ago in a pile of parts. |
06-09-2006, 11:34 PM | #15 |
Rock Crawler Join Date: Sep 2004 Location: Santa Rosa
Hell for $79 you could have got a complete kit with suspension stays ans lots of extra screws from HobbyPeople.net. I thought about purchasing the pieces individually but figured the price it would cost I might as well get the whole kit.
06-10-2006, 02:11 AM | #16 |
Yeah, thats what I did I bought the whole kit.
06-10-2006, 10:05 AM | #17 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
You're crazy man.Where do you get these ideas?Hope it works!
06-13-2006, 09:22 PM | #18 |
Bought some delrin, fiberglass, and the big rod ends to make the chassis. I have decided to build a ladder style chassis. The stick was to hard to manuver over the trans. Plus I want something different.
06-14-2006, 01:54 PM | #19 |
Wow, stuff came today! Mcmaster ships like 1 day flat.:-P I'll put up some pics later tonight.
06-14-2006, 03:14 PM | #20 |
Rock Crawler Join Date: Sep 2005 Location: wyckoff, NJ
I'm excited!
