12-13-2004, 07:38 AM | #1 |
Pebble Pounder Join Date: Jun 2004 Location: Oklahoma
| Motor for TLT
Would a magnetic mayhem motor fit on a TLT that has an extended wheelbase? Would Lathe motor? Would any stock 27 turn?
12-13-2004, 09:43 AM | #2 |
Rock Stacker Join Date: Dec 2004 Location: Hillsboro, oregon
| Re: Motor for TLT
i know a 27 will, i have a p2k pro2 right now until i get a lathe motor and for being a 27 it works fine
12-13-2004, 09:54 AM | #3 |
Quarry Creeper Join Date: Nov 2004 Location: SW Indiana for four more years...
| Re: Motor for TLT
The MM and lathe motors are 540-size motors so both will work. Any 540 size motor will fit.
12-13-2004, 10:36 AM | #4 |
| Re: Motor for TLT
I was not aware that MM and lathe motors were 540 in size. Thanks for help
12-13-2004, 10:51 AM | #5 |
Rock Crawler Join Date: Apr 2004 Location: Longmont, CO
| Re: Motor for TLT
Don't own a TLT but aren't MM's a little longer than normal? Dunno how tight the motor mount is in a TLT... Lathe motors are actually a little shorter than normal. |
12-13-2004, 01:36 PM | #6 |
| Re: Motor for TLT
Several peeps are running the MMs. They fit, but I don't recall any mods having to be done to the chassis or radio tray because they are longer. Should be a simple drop-in motor.
12-13-2004, 01:38 PM | #7 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
| Re: Motor for TLT
Mag Mayhems are 550 which is a little bigger. It should fit, the motor cut out in the chassis seems a little longer than nessecary. I personally like the Multiplex 600, but that might be too long for the stock TLT chassis and tranny.
12-13-2004, 01:51 PM | #8 |
| Re: Motor for TLT I thought the MMs were 540s.
12-13-2004, 05:36 PM | #9 |
Newbie Join Date: Apr 2004 Location: south central
| Re: Motor for TLT
A MM will fit in a stock TLT. I have, opps, had one in mine when it was together. It will also go back in the modded truck until I find something else that I might like better.
