12-13-2004, 09:59 AM | #1 |
Pebble Pounder Join Date: Nov 2004 Location: Thomaston, CT
| Project help
Hopefully this weekend I will start mapping out my TLT crawler project (TLT better show up soon ). My plans are to run the TXT tranny I have with stock TXT driveshafts. I just read that the TLT axles have the cup output. Does anyone know how I can convert that to the metal tab such as the TXT axles? Also I have a 2 ideas in my head, wondering if anyone has opinions. 1. Go more for scale with a Bronco body, Imex Swamper Dawgs (2.2), 11-11.5" WB, front steering. 2. More rock crawler, with a CJ8 body (looks better with the longer WB, and looks better with the fenders cut a little bit more for tire clearance), same tires, 12.5-13" WB, 4ws. Regardless I plan on running a 55t lathe, and setting the tranny up a little higher than most to add for ground clearance (set everything else down, especially the battery to gain lower overall COG). |
12-13-2004, 10:35 AM | #2 |
Quarry Creeper Join Date: Nov 2004 Location: SW Indiana for four more years...
| Re: Project help
The TLT axle pinion shaft is 5mm dia. The TXT tranny shafts are 6mm. You should be able to use a combination of the T-Maxx tranny yokes (5mm) for the axles and E-Maxx tranny yokes for the TXT tranny, then run the Maxx sliders for the drive shafts. Traxxas has an X-Long slider out for the 2.5Maxx with the widened suspension for the 13" WB option. The Maxx yokes are designed to have a pin to secure them. One hole is 4mm threaded, the other isn't tapped at all, but a 3mm screw will self-tap in the hole. Use a 3mm and a 4mm set screw for each yoke. I know Dubro has both in 4mm and 6mm lengths. |
12-13-2004, 01:43 PM | #3 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
| Re: Project help
I'd go with #2. You'll get bored of scale real fast.
12-13-2004, 06:17 PM | #4 |
Rock Stacker Join Date: Sep 2004 Location: MI
| Re: Project help
Sounds like a fun project. Your options only vary by two inches so they will both look semi scale with the 1/10 scale body. Use the longer wheelbase for added stability, but again, with 2.2s on TLT axles under a 1/10 body, it's going to look somewhat scale. Hurry up and finish it so we can see some pics!!! :P |
