06-23-2006, 03:42 PM | #21 |
Rock Crawler Join Date: Aug 2005 Location: White Lake
It going to turn out good.
06-23-2006, 05:04 PM | #22 | |
06-24-2006, 03:43 PM | #23 |
Should i start the mods already |
06-24-2006, 04:16 PM | #24 |
so i was heading out for a crawl with my clod and it started pouring , so i satyed in and couldn't resist, the tires look kind of goofy but i will strech the chassis |
06-24-2006, 06:22 PM | #25 |
Then i installed the tobbee spacers , these are wide check them out , i still haven't streched it here, probably will do it tomorrow |
06-24-2006, 06:27 PM | #26 |
WOW! Those things are W I D E! Stock up on bearings and order a set of aluminum knuckles. I have a feeling your going to need them.
06-24-2006, 06:38 PM | #27 |
already have them , knuckles and bearings , just haven't installed them |
06-24-2006, 06:46 PM | #28 |
Cooleo!
06-27-2006, 08:37 AM | #29 |
| that's all ican say, wow and extremely happy, so far: penguin chassis tobee craft wheel spacers tobee craft links moped esc moabs 2.2 acoms fm 4 channel radio/ 3 servos 4ws tlt kit stock 540 integy 55t on it's way i do have one question, can i install a 9 tooth pinion on the stock tranny? |
06-28-2006, 12:16 PM | #30 |
actually now is 2 questions , 1-can i use a 9 tooth pinion from a clod on the tlt-1 stock tranny? 2-i looked didn't find the tread, how do you lock a stock tlt-1 tranny? |
06-28-2006, 12:22 PM | #31 |
Clod has 32 pitch gears and the TLT uses 48 ptich gears so they are incompatible. Keep searching about the tranny. There's a million threads on it. But I would say use JB Weld or some sort of epoxy. Gonna need to put some sort of tensioner on that belt too... locking center diff tlt? Last edited by K_B; 06-28-2006 at 12:25 PM. |
06-28-2006, 12:35 PM | #32 |
thanks KB i did some searching but most of the threads talked about the pede tranny upgrade or some other kind of modified tranny, i will stick to the stock one for a couple of weeks, thanks again for the link |
06-28-2006, 06:41 PM | #33 | |
Newbie Join Date: Jun 2006 Location: Los Angeles
it will take some noodling around, but if you get it in just right, the covers will fit on there perfectly... i just finished my tlt build, but i used the tracer chasis 1/10 conversion kit, very nice, alloy shock mounts etc etc... type "tracer tlt" in the bay and it should pop up... there are also alot of nice parts from the same manufacturer, but if you order the conversion kit, it comes with everything you will want... as for your belt tranny, there are a coupla ways to lock your ball differential inside the tranny.... tighten the crap out of it, (it will still slip a little... i tried this and i didn't like it) jb weld, crazy glue (these are permanent, just put the glue over the ball bearings inbetween the plates and make sure that you cant spin the diff after your done... i used crazy glue... love it... world of difference in climbing) hot-glue (same concept as the jbweld, and crazy glue, not permanent, you can remove it later) hope that helps... -james | |
06-28-2006, 06:43 PM | #34 |
so i finished the tlt-1 , for now , tell me what you think
06-28-2006, 06:46 PM | #35 |
thanks james, i will go the hot glue route , as i don't want to ruin the parts permanently.
07-01-2006, 10:08 AM | #36 |
so i finally decided to lock the diffs , and install the aluminum hub carriers that had been sitting around for a couple of weeks, later i'll do the rear diff and hubs also will lock the stock tranny , while i can get a hold of better tranny, anyone knows if the traxxas bandit tranny might work? i also have a team losi buggy for spares, don't remember the model but here is a picture , any one done this tranny?
07-01-2006, 11:02 AM | #37 |
That tranny should (lose the Hydra Drive) work if you can fit it is that chassis. Truck looks good. Order a 1/10 scale body for it! |
07-01-2006, 12:42 PM | #38 |
i did ,i ordered a... rubicon , i know everyone in the states has them, not here though , mine is going to be unique |
07-01-2006, 12:52 PM | #39 |
Cool. The Rubi is a nice body, just lots of them. |
07-06-2006, 02:12 PM | #40 |
a couple of poser pics , still waitng on the new body and tranny locker |
