12-27-2004, 11:41 AM | #1 |
Newbie Join Date: Nov 2004
| CheroKrawler II (Updated - Video Page 2)
Well with the failure of the first one, the redsign will consist of: 3/16 tube chasis, EMAXX tranny, 55t lathe motor, 9t pinion, and Super Rooster. Going for a 13" wheel base, 3 to 3.5 center clearance. Haven't decided on the an driveshaft yet, REVO, TRAXXAS slider, or Jugg. Any suggestions? Again, I based it of my XJ...an old version!!! This a mock up with the top half of the chasis to double check everything is in scale (the battery was only used to hold the front half down). Joe |
12-27-2004, 11:45 AM | #2 |
Quarry Creeper Join Date: Jul 2004 Location: Elizabeth City NC
| Re: CheroKrawler II
Should be sweet. What are ya gonna do for a body?
12-27-2004, 11:53 AM | #3 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
| Re: CheroKrawler II
It'll probably just be a tuber. I would if you could find some get like a sheet or two of lexan and make your own body panels. Then it'd look even more scale to your truck. For driveshafts, I would just stick with some emaxx shafts. Revo's are a bit overkill for these trucks. Personally, I'd rather have a traxxas driveshaft blow out then a more vital tamiya component in the axle, since traxxas parts are easier to come by. It should be good, what shocks are you going to go with? |
12-27-2004, 11:56 AM | #4 |
| Re: CheroKrawler II
I've searched everywhere on the net and LHS's and no one makes a Cherokee body or model. Just Grand Cherokee's. So it's just tube and some body panels to get the resemblence.
12-27-2004, 12:59 PM | #5 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
| Re: CheroKrawler II
Did you look for barbie cars?
12-27-2004, 01:31 PM | #6 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
| Re: CheroKrawler II
Looks good, I like the cherokee theme. I would stick w/ 2.5 maxx shafts for a scale rig, they should be strong enough. |
12-27-2004, 02:27 PM | #7 |
Rock Stacker Join Date: Oct 2004
| Re: CheroKrawler II
Good work I think it allready looks more XJ'ish then your previous attempt, and looks like quality craftsmanship
12-27-2004, 06:27 PM | #8 | |
| Re: CheroKrawler II Quote:
Another day and no tranny. I'm losing my patience...friggin holiday season. | |
12-30-2004, 08:26 PM | #9 |
Quarry Creeper Join Date: Mar 2004 Location: 18" from computer screen
| Re: CheroKrawler II
one thing I see it that you need to extend the cage off the back a little bit to give it some more scale appearance. Other than that it looks great man!
12-31-2004, 01:42 AM | #10 |
| Re: CheroKrawler II (The Learning Experience)
Well the tranny showed up and this now project has taken another turn. I had it all mocked up and tested the articulation. Needless to say the squared rear of the frame limits articulation...badly! So now I'm just applying everything I've seen and read about building a crawler. The priorities have changed...capabilities is what's important now, instead of looks. That'll come later. It's still scale, but it's starting to look like some alien erector set w/ Mickey Mouse (the tranny) sitting in the middle of it. |
12-31-2004, 02:15 AM | #11 |
| Re: CheroKrawler II
In the picture, just remove the lowest bar on your chassis in the back. It'll still have the squared look of the cherokee, and like I said, get some lexan sheet to fab up some skins for it, and that'll hide your tranny a bit. Also, get some more pics! |
12-31-2004, 07:16 AM | #12 |
Quarry Creeper Join Date: May 2004 Location: ROCK CRAWLIN AND RACING WHERE I WANT AND HOW I WANT!!!
| Re: CheroKrawler II
Looks sweet... I really like the idea of an xj I never thought of building one like that and hell I own two xj's and one zj so thanks for the idea and I can't wait to see your crawler done. Really nice work. |
12-31-2004, 12:44 PM | #13 |
Rock Stacker Join Date: Sep 2004 Location: MI
| Re: CheroKrawler II
Being a Cherokee owner myself, I love your idea. It's pretty cool how much your tube frame resembles the real vehicle. Seriously, with some strategic placement of lexan body panels, it will look like the real thing. Keep the pics coming....we need updates!!! |
01-01-2005, 05:42 PM | #14 |
| Re: CheroKrawler II (Update - Rolling Chasis - 1 Jan 05)
The chasis is complete. NO binding and excellent articulation (between 70 - 80 degrees). Still need to pick up a Super Rooster, Lathe Motor, 9t pinion, 2nd battery and some decent shock mounts. Then it's play time again while address the body design. Wheelbase is 13.5" Center Clearance is 3.5" TLT axles EMAXX tranny Traxxas Sliders MAXX shocks w/ 50 wt oil (I guessed on the oil) Still have make the rear axke skid |
01-01-2005, 06:37 PM | #15 |
| Re: CheroKrawler II [b](Update - Rolling Chasis - 1 Jan 05)
Nice! Those look like hotbodies shocks, so I'll give you this advice, make sure the shock mounts at the axles aren't pinched at all. I've broken 3 hot bodies plastic shock ends. I just upgraded to traxxas and haven't had a problem yet, but I only had a few runs on it today.
01-01-2005, 07:58 PM | #16 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
Does having the battery pack on that one side make it tip over on that side? Seems like it would.
01-02-2005, 06:20 AM | #17 |
The second battery will be mounted on the opposite side to balance it out. I really won't know until I get the rest of the parts and get it running.
01-02-2005, 12:05 PM | #18 |
Quarry Creeper Join Date: Aug 2004
xjk9bar1, looking real good! i like you axles gaurds. run it yet? |
01-03-2005, 05:30 AM | #19 |
No, still have to pick up motor and ESC. Hopefully w/in the next week or two.
01-08-2005, 06:35 PM | #20 |
| Re: CheroKrawler II (Updated - Video Page 2)
Here's clip of CheroKrawler. The first scene is me crawling in the garage (I'm all finesse), the last 2 scenes is my friend (he's all throttle). My ESC (MC230CR) worked like sh*t w/ the P2K motor. Reverse wouldn't work. But now it works great w/ the Integy Lathe. Go figure! http://www.one18th.com/gallery/albums/album01/nwj.wmv |
