![]() | #61 |
Rock Stacker Join Date: Feb 2007 Location: lincoln
here is one ![]() |
![]() | #62 |
Newbie Join Date: Feb 2007 Location: atlanta
could i use clod axles and links on a tlt chassis???
![]() | #63 |
RCC Addict Join Date: Jan 2007 Location: San Jose
![]() | #64 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
![]() | #65 |
Newbie Join Date: Jan 2007 Location: Lincoln
Where do you get the 3/16" roll pin to make the longer driveshafts? Are these an rc part for another car or something you can pick up at a hardware store?
![]() | #66 |
Nevermind... I went to the hardware store today and got them. I really like inexpensive options such as this. Cost an entire 58 cents!!
![]() | #67 |
RCC Addict Join Date: May 2005 Location: I live Here
this thread left out the tracer conversion and re-gearing the the stock setup for crawling the 24/83 setup just doesn't cut it. any advice on this ? ? ? |
![]() | #68 |
Read and learn thanks to you!:-P
![]() | #69 |
Nice machines.
![]() | #70 |
Rock Stacker Join Date: Oct 2006 Location: phoenix
i have a xl-5 rustler not stampede i know their baisicly the same thing for crawlers but i was noticing that the tranny for the newer ones were different than the older older say stampede can i use the newer rustler mount and if not can i swap out the gears from the new tranny xl-5 for the older stampede tranny
![]() | #71 | |
Newbie Join Date: Jul 2007 Location: S
| ![]() Quote:
![]() | #72 |
Newbie Join Date: Aug 2007 Location: LakePort
YA I found out the hard way the buying the axles is not the way to go, but I found out after they were already here(all but 2 parts.) Next one will be a whole kit..
![]() | #73 | |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
| ![]() Quote:
But, you can basically just stuff the JB in between the spider gears, as long as the two outer halves will close, and the hole in the center will still let the axle shafts slide in and seat, you are fine. ![]() | |
![]() | #74 |
Rock Stacker Join Date: Oct 2007 Location: beaverton
dont know if this has been covered but i found it on another site for locking the diffs. will this work... ![]() You can lock the axle diffs in one of two ways. First way is to simply use jb weld on the diff axle gears and have them basically glued together. Make sure the gears fit into the diff housing and everything goes back together cleanly and right. The 2nd way is easier and reversible. You simply take one of the 3 spider gears off the 3 pointed holder and place the gear you just removed in between the other two gears that are still on the holder. Put the diff back together and there you go locked diff! If you should ever feel the need to unlock it you will just have to put the gear back into it's correct place. thanks in advance and sorry if its been covered already... ![]() |
![]() | #75 | |
| ![]() Quote:
Have fun!! | |
![]() | #76 |
thanks alot ive been looking around awhile and was woundering how it would work...
![]() | #77 |
Newbie Join Date: Feb 2007 Location: Denver / Northglenn
I went to my LHS and bought 2 sets and put a total of 6 in both diffs
![]() | #78 |
sorry for the mess up
![]() | #79 |
i used the 4 gears in each diff and it worked great. i think 6 gears in each diff is a lotta over kill and probably hard to get put together but hey i hope it works out well for you... ![]() |
![]() | #80 |
i loaded em up w/ 6 dif gears - not 2 hard to get together they are heavier now thats for sure - i wanted to bulletproof them as much as i could. |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/tamiya-tlt-crawlers/3996-faq-tlt-1-tlt-crawler-%2A%2A%2Anewbies-read-%2A%2A%2A.html | ||||
Rock crawling? | This thread | Refback | 02-24-2013 11:22 PM | |
ORCRC.COM | This thread | Refback | 10-04-2011 07:13 PM |
