![]() | #81 |
Rock Stacker Join Date: Oct 2007 Location: beaverton
the more weight you have at the axles better off you are. i dont know how you did it but congrats. i had a hard enough time getting the four gears into the diff housing and bolting it shut...
![]() | #82 |
Rock Slayer ![]() Join Date: Jul 2008 Location: Fox Valley WI
I have a quick question for a friend of mine with a TLT. He keeps breaking the stub shafts, right where the threads end. Is there an updated list of other, stronger shafts that'll work? Thanks in advance ![]() |
![]() | #83 |
Newbie Join Date: Nov 2007 Location: Naperville
rc4wd has stainless shafts or you could get the cvds from rcp but there twice the price
![]() | #84 |
Rock Crawler Join Date: Feb 2008 Location: Georgetown, TX
Please, no flaming, and yes i did use the search. I am going to start a 6x6 project with TLT axles. I know you can use the two like cases for the middle axle, but does anyone have pictures of how they did it?
![]() | #85 |
Found this by searching through the general crawlers section for "6x6". And as I figured, it's a link that goes to Scale 4x4 http://www.scale4x4rc.org/forums/showthread.php?t=15970 |
![]() | #86 |
Thank you very much K B, my searching abilities need work.
![]() | #87 |
no problem. you'll begin to see a pattern as to where stuff is generally located. 6x6s and 8x8s usually fall under General or the scale section.
![]() | #88 |
Newbie Join Date: Jul 2007 Location: Adrian
I had a question but I think I answered it by reading through. thanks for all the great info.
![]() | #89 |
Quarry Creeper Join Date: Jan 2007 Location: Las Cruces, New Mexico
so anybody have a good pic of the truck w/o a body on it of this setup? im trying it out but i have no pics and really no idea how you setup the tie rods
![]() | #90 |
Quarry Creeper Join Date: Oct 2008 Location: fullerton
i just got some tlt axels and i want to put bearing every where wat sizes and quantity do i need for these axels?
![]() | #91 | |
Quarry Creeper Join Date: May 2008 Location: Out in the country
| ![]() Quote:
![]() good luck ![]() | |
![]() | #92 |
Newbie Join Date: Jan 2009 Location: Rural Mn. near Fargo, ND
That looks like a lot of work. I've just swapped the stock dogbones for ones from an old Kyosho Raider in my "don't use that anymore" pile. I installed the dogbones, layed out the suspension, and lengthened the rest of the stock links with 6/32 allthread. (You can get 3 ft sections of the 6/32 allthread @ Home Depot for under $3) I would suggest covering the bottom links with alum or brass tubing. I left the others raw, they don't touch the ground or bind on anything. |
![]() | #93 | |
| ![]() Quote:
![]() Good luck & happy crawling. | |
![]() | #94 | |
| ![]() Quote:
Also if you get the cvd's they come with (4) bearings to replace the bushings in the knuckles. | |
![]() | #95 |
Pebble Pounder Join Date: Aug 2009 Location: taiwan
"For the axles, first ditch the bumpers, they ruin your approach angle, and take away from under axle clearance. Then move the steering links above the steering arms. Next move the upper links to the back of the axle, and the lower links to the top to remove clutter under the axle. You will need to buy some longer screws and do some shaving or some shimming. I didn't have a dremel at the time, so I shimmed. Please note that doing this mod will extend out your wheelbase and you will have to run the 96mm link on the bottom and the 108mm link on top):" Does anyone know the wheelbase after doing this mod? what's the length increase compare to original? Can I still using stock shocks? Thanx! |
![]() | #96 |
Old guy ![]() Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
Does anyone know if the TLT ring and pinion interchange with the hi lux .
![]() | #97 |
RCC Addict Join Date: Nov 2005 Location: Kansas
I'm about 67.4% sure that TLT R&P's are the same in the Hi-Lifts I haven't had a set of Hi-Lift axles in my hands... |
![]() | #98 | |
| ![]() Quote:
I am hoping so, just blow the middle axle out of my duck. I got tons of TLT gears. I will tear it down this weekend and post back up. ![]() | |
![]() | #99 |
MODERATOR™ ![]() Join Date: Jul 2004 Location: Ohio
Yes they'll work. Only difference would be the hole for the diff locking set screw.
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/tamiya-tlt-crawlers/3996-faq-tlt-1-tlt-crawler-%2A%2A%2Anewbies-read-%2A%2A%2A.html | ||||
Rock crawling? | This thread | Refback | 02-24-2013 11:22 PM | |
ORCRC.COM | This thread | Refback | 10-04-2011 07:13 PM |
