08-21-2006, 04:12 PM | #21 | |
RCC Addict Join Date: Sep 2005 Location: ...Here & There
And, your closer than me! That does look sweet J! | |
08-21-2006, 04:17 PM | #22 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
External Springs? Do I win a cookie? |
08-21-2006, 04:21 PM | #23 |
Quarry Creeper Join Date: Apr 2006 Location: Gervais
Does it offer more travel like that?
08-21-2006, 04:29 PM | #24 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
Raytard and Unholy get a cookie.... Revoster.. No it doesn't. When I put the internal springs in it didn't give it enough "lift" so I added the smaller outer spring to give it the extra lift it needs until I can find an internal spring that is a bit stronger. Last edited by Double J; 08-22-2006 at 08:28 AM. |
08-22-2006, 01:28 AM | #25 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
Man this looks much better assembled. I looked at it in the FS forum and thought "Man, that's an interesting looking little thing".
08-22-2006, 01:50 AM | #26 |
How about Papa Roach?
08-22-2006, 09:25 AM | #27 | |
Didn't get to do anything last night but might have something done for lunch. and I'll update the pics. I purchased the wrong rims so I'm taking them back to get the correct ones so I can get them on correctly. Don't be in a hurry when buying things. I didn't even read the package, just grabed and go. Papa roach or maybe Dilatory Roach. Any other suggestions I really hate naming things. | |
08-22-2006, 10:14 AM | #28 |
Quarry Creeper Join Date: Jul 2006 Location: Ontario, NY
I like the looks of that chassis... How about Punkin Head? |
08-22-2006, 12:31 PM | #29 |
Should I add some flames or graphics of some sort to the panels?
08-22-2006, 01:18 PM | #30 |
I wouldn't. Just add some small logos and numbers. Make it look like it as some sponsers.
08-22-2006, 02:40 PM | #31 |
Damn nice tuber J, I like your foam cuts too, how do they work with the side wall flex?
08-22-2006, 06:49 PM | #32 |
Unimog - I don't know how the foams will work right now. I cut some similar to these for microgoat to test. Like in Jan. or Feb. But these have a bit more support. They seem to be good from what I can tell. As far as the paint I think I'm going to put 01 on the side and make it kinda like the general lee. I'm not sure yet though. Thanks all |
08-23-2006, 08:41 AM | #33 |
Here are a couple pics with the electronics and the servo in place to show how it will fit in there. I need to make two seperate battery packs out of the stick pack I have and that will mount on the front and rear of the tuber. Articulation with the servo. I may need to extend the wheel base about 1/2 an inch. But when the body hits the servo it is just at the end of its travel. |
08-23-2006, 09:18 AM | #34 |
Manic Mango? That looks sweet, I like the curved panels in the fenderwells. Those foams work great, lots of sidewall support but with squishy tread. |
08-23-2006, 09:27 AM | #35 |
Do you still use the ones I made you? These foams actually only took about 10 minutes to cut all 4. I didn't make the "Pivot" under the pads because they will need to handle more weight. I did trim about 1/2 inch off the sides. For some reason the foams were bigger than the tires wasn't like that on the other tires I had. It was kinda funny though when I first put the foams in it made the tire deformed, like when you were a kid and the tube started coming out your bike tire because you left to many skid marks on the pavement. |
08-23-2006, 10:35 AM | #36 |
Dilatory Crawler build has a real name now... It will be called "General Crawler" the name was given to it by it's new owner - RustyCrawler. It will be receiving an "01" on the sides and the front will read GENERAL on it. Incase anyone was wanting to know what DILATORY (wich I misspelt on the title) means. dil•a•to•ry adj. 1: inclined to waste time and lag behind [syn: laggard] 2: wasting time [syn: laggard, poky, pokey] 3: using cautious slow strategy to wear down opposition; avoiding direct confrontation; "a fabian policy" [syn: fabian] dil•a•to•ry adj. 1. Intended to delay. 2. Tending to postpone or delay: dilatory in his work habits. See Synonyms at slow. Last edited by Double J; 08-23-2006 at 10:37 AM. |
08-25-2006, 08:00 PM | #37 |
Just thought I would let you know. I was looking for wideners and had a hard time getting the blackfoot ones around here and found another option. I used associateds 3/16" axle stubs. I worked great. I'll have pics soon of all the updates on this thing. For info on the axle stubs I posted how to make it work in the sticky at the top. |
08-25-2006, 08:08 PM | #38 |
Quarry Creeper Join Date: Aug 2006 Location: Spring,TX
| hi
nice mod find |
08-25-2006, 08:22 PM | #39 |
I knew what it meant I still use those foams, don't have a lot of choice with 'em glued inside the tires |
08-25-2006, 08:55 PM | #40 |
Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
There is one thing bugging me about this rig. Why is there one screw that isn't powdercoated like the rest?
