09-13-2006, 07:31 AM | #61 |
Quarry Creeper Join Date: May 2005 Location: Between rocks and hard places
I agree with you both (Mad Scientist, StatusZuk) but to add a little to the topic. Not being sure cause he doesn't have a flat level picture but all articulated pics. Displaced air is displaced air whether it be in line bulge or shock extension. If airs not displaced it's leaking somewhere. That being said, I don't think he'd have the shocks fully extended on a flat surface cause that wouldn't leave room for the shocks to be able to move in and out. That would be like filling one shock to the rim with oil. The shock won't compress. I like the rubber glove analogy but they are a lot thinner than the hydro lines that he's using. My 2pennies.
09-13-2006, 09:29 AM | #62 |
RCC Addict Join Date: Aug 2005 Location: Naoma, WV
Air is compressible, shock oil is not. I don't know the particulars of this system, like the stick TLT, going to have to try it and find out. But it is possible to have all 4 shocks fully extended at one time and all fully compressed at another. The time where all 4 are compressed will just increase the pressure.
09-13-2006, 10:39 AM | #63 | |
RCC Addict Join Date: Mar 2005 Location: Saginaw
09-13-2006, 10:53 AM | #64 |
RCC Addict Join Date: Jan 2006 Location: The Amish Ghetto
its just like springs at that point... the amount of air he is running is like a 1.7lb spring. the air gets compressed the same as that spring, the only thing that is different is the shocks are linked together. so if you compress the front right all the other shocks are trying to push back towards that shock, basically making them a higher pressure at that point due to the displaced air........ i think that in its self makes this system superior for nosing over climbs and other actions comon in crawling. |
09-13-2006, 03:24 PM | #65 |
Rock Stacker Join Date: Jun 2005 Location: anaheim
i know this is off on ur arguments about were the air goes when one shock is compressed, but i have two things to point out: 1st this is one tight rig and very smart. 2 doesnt the shock pistons have holes in them? now my main reason for loging on (it has been months): earlier you have discussed what would be next, well i got an idea: why dont you have the front and rear on there own airsystems, and hook up a nother shock and have a survo working the other end, so you can add a front and rear drop!! to do this you would have to have shock/serringe(sp...the thing nurses use to draw blood on inject meds in to people) fully deextended then fill the system with air so when you have the servo pull the shock/serringe it will lower!!! ps. i just thought of this now and just typed it out b4 i forget. i have no experience in this nor did i try it...but it was JUST A THOUGHT. |
09-13-2006, 03:45 PM | #66 | |
Pebble Pounder Join Date: Mar 2006 Location: Paradise
only thing I see about having the shocks connected is, if you start to go on a side hill the loow side shock will want to compress wich will make the high side want to extend, and it will probably fully compress the low side and fully extend the high side, which will give you horrible body roll. But enough talking we need some videos of this thing to see how it really does. | |
09-13-2006, 04:06 PM | #67 |
Yeah I'm ready for some vids. I think we all discussed, not argued, the original poster right out of his own thread.
09-13-2006, 05:11 PM | #68 |
Rock Stacker Join Date: Nov 2004 Location: wildomar
i have another idea! how about you use the same air system and fill it up with oil. then where all the lines connect, hock it up to another shock and that fifth shock will turn into a master cylinder. then hock up a servo to that master cylinder. then you can adjust your ride height and stiffness. if you make a master cylinder for the right and left side of the crawler, you will be able to adjust the angle, stiffness, and ride height of the truck. just think what you can do if you had a master cylinder for all four sides...... you would have to have your buddy control the suspension well you drive or you can even put a gyro on the crawler and it will self level its self. just an idea. |
09-13-2006, 05:55 PM | #69 |
that wont work, you cannot compress liquid.... the whole system is based on the added friction of the compressed air.
09-13-2006, 06:06 PM | #70 |
i know you can't compress fluid, that's is why you have a master cylinder (extra shock) as a chamber and it works as a compressor or a decompressor
09-13-2006, 06:39 PM | #71 | |
09-13-2006, 06:41 PM | #72 |
Pebble Pounder Join Date: Nov 2005 Location: huntsville
Ok quick vid. no editing, sorry. I was trying to get some good vid and my cheap-o ESC crapped out. Oh well. http://media.putfile.com/airshocks |
09-13-2006, 06:46 PM | #73 |
RCC Addict Join Date: Jan 2005 Location: Green River Kentucky
I think we are in trouble |
09-13-2006, 06:49 PM | #74 |
Rock Crawler Join Date: Jan 2006 Location: Dallas
awsome vid looks like a cool little place to crawl.
09-13-2006, 08:34 PM | #75 | |
I like how for the music you had the radio on in the background | |
09-13-2006, 10:13 PM | #76 | |
Great vid! Looks like it handle real well. Last edited by Thundermaxx; 09-13-2006 at 10:16 PM. | |
10-18-2006, 11:07 AM | #77 |
Pebble Pounder Join Date: Mar 2004 Location: Griffith
Can you give us an update on how this setup has been working??
10-18-2006, 11:58 AM | #78 |
Pebble Pounder Join Date: Jan 2006 Location: Calgary Alberta Canada
I would also like to see the long term effects on the system.
10-18-2006, 12:44 PM | #79 |
RCC Addict Join Date: Apr 2005 Location: Seattle
No kidding. I have some TLT shocks sitting here doing nothing...
10-18-2006, 02:02 PM | #80 |
Pebble Pounder Join Date: Apr 2006 Location: meriden
i think i have a solution to the problem that the guy with the air ride suspension has been having. i saw this trend started, and read all 4 pages so i can get a little info on the idea. a solution to the hose comming off the fitting problem will be this,.... go to a paintball pro shop, and ask for an internal hose kit for some of the electronic paintball markers, and find the one kit that contains the proper length hose size u need. get the barb fittings, and then replace ur equipment with the new hoses and fittings. i know for a fact, that the hoses will hold a high amount of PSI because the hose kit in my paintball marker is rated for high pressure @ 800 psi... |
