10-07-2006, 03:53 AM | #21 | |
| Tires Maybe? Quote:
I think it might have to do with the fact that the Mashers have a wider tread area so there's less pressure whereas the Moabs are narrower and apply more pressure to a smaller area. Or... it could all be in my head. I'll have to do more tire swapping to know for sure. | |
10-07-2006, 04:47 AM | #22 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
That is the most awesome crawl spot I have ever seen. Nice. Cheers 8-) |
10-07-2006, 07:10 AM | #23 |
| nice rig, awesome crawling place too, you just made me want to get back and finish my XRC, thanks man for the inspiration. |
10-07-2006, 05:34 PM | #24 | |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
i also noticed at our last comp that with the high clearance links, i had no trouble clearing some areas of the courses but others had trouble. i am still playing with a setup for the left rear shock to try to eliminate some of the torque twist between the springs/oil weight thanks guys for the compliments Last edited by yukon635; 10-07-2006 at 05:36 PM. | |
10-07-2006, 06:46 PM | #25 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
One thing I did was drill more holes in my tire to let the air flow in and out much faster. I like how my Mashers perform a LOT better now because of it. I also cut grooves on the outside of the foams, in addition to the star pattern. |
10-07-2006, 08:05 PM | #26 |
i have four breather holes in the wheels and run almost no foams but because i added sidewall tread to them, the sidewall seems to be a little stiffer. i dont know we shall see. i liked the star pattern but didnt like all the hop that came with it.
10-07-2006, 11:35 PM | #27 | |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
10-08-2006, 10:04 PM | #28 |
Moderator Join Date: Apr 2004 Location: In my head
Love the truck can't wait to get my XRC going. Where is that crawl spot?
10-08-2006, 11:15 PM | #29 |
its here in auburn at Chewacla state park. its a good place to crawl down by the waterfall but you have to walk down hill for a good 75 yds. thru a small walking trail. thats not bad, but going back up will kill you. i have to charge all my batts before i leave and take them with me to make the trip back up worth it
10-08-2006, 11:38 PM | #30 | |
With straight links, the links will drag before tire makes contact with the edge so you gotta have some extra oomph to slide the links along. This info may be obvious to most, but it actually didn't make sense to me until I ran my straight-linked rig the other day. :? | |
10-08-2006, 11:43 PM | #31 |
yeah, in those last series of pics, showing it crawl thru that crack, there is now way that i would have made it up that with ease like i did with the high clearance links. well i might of made it up but with a little umph and maybe some sliding until the tires grabbed, by then i might have hit a gate marker at a comp.
10-09-2006, 08:23 PM | #32 | |
10-10-2006, 02:50 AM | #33 |
Quarry Creeper Join Date: Aug 2006 Location: So*Cal
just curious what brand of paint you used & what color it happens to be. every time I see your bug i stare at it for 5 minutes. PM me because i'm curious as to the steps you took to get that amazing look. thanks!
10-10-2006, 11:34 AM | #34 |
it is tamiya copper paint. all i can say about painting bodies is the more you do, the better you get. make sure you clean the inside of it off really good and get all the little dust/lint particles out of it. I like to measure and make the holes for my body posts before i paint just cause you can see them. jmo. and when you do the window masks or using liquid mask for a design, make sure everything is pressed down good and that they make a tight seal. then spray away
10-10-2006, 11:36 AM | #35 | |
