09-22-2006, 04:29 PM | #21 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
what time are you going sunday?
09-22-2006, 04:53 PM | #22 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
Aaron did you shim the diffs? If not you may want to do this. We've been seeing a big number of blown ring and pinions lately. The one in my new rig only lasted 2 days at the nationals and about an hour after that.
09-22-2006, 05:16 PM | #23 | ||
Quarry Creeper Join Date: Oct 2005 Location: SoCal
Is this what I wanna use to shim the ring and pinion Traxxas Fiber Washers 5x8mm part # 1985 http://www2.towerhobbies.com/cgi-bin...&I=LXJJ88&P=ML | ||
09-22-2006, 07:16 PM | #24 | |
Pebble Pounder Join Date: Sep 2006 Location: La Verne
09-22-2006, 07:22 PM | #25 |
Rock Crawler Join Date: Jan 2005 Location: Post Falls
Yep, mine blew out about 5 min after Brians on the same rockpile. Just got the parts to fix it. Ohh and by the way that brushless motor is sick!!!! |
09-22-2006, 07:32 PM | #26 |
RCC Addict Join Date: Jul 2006 Location: So Cal USA
Nice Job Aaron, looking forward in competing with that machine What about the shimming? Where exactly do they go? Whats Up Twisted420 |
09-22-2006, 07:59 PM | #27 | |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
09-22-2006, 08:01 PM | #28 |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
looks great, aaron! i have the TLT shocks on my SW2 rig as well. they seem to work fine. my pop will be running in 2.2 at mt. baldy..........with a VW body! |
09-25-2006, 09:59 PM | #29 | |||||
Looking forward to competing with you ALL this weekend Here's a few picture's from Sunday at The Spot Quote:
Now One shim to push the ring gear towards the pinion I had it setup One shim behind the pinion inside the axle to push the pinion gear towards ring gear. Quote:
Bender View Top View Last edited by Johnson420; 09-27-2006 at 09:34 PM. | |||||
09-25-2006, 10:39 PM | #30 |
Few questions about the street sport output... -did you cut the shaft off ? -How are/do you change driveshaft ? If and when it breaks or need to joint ? To me it seem like a pain in the @ss to change since you welded the street sport output yoke to sleath output yokes. |
09-25-2006, 11:35 PM | #31 | |
The shafts are cut just short enough to fit inside the outdrives, one outdrive is deeper than the other. The DRIVE SHAFTS just snap on and off the steel outputs on both sides. And since all the output yokes are steel they shouldn't break. If I did need to open up the stealth for some reason, I would need to grind off the two little spot welds. no biggie | |
09-26-2006, 01:05 AM | #32 | |
rig looks great though, I can't wait to compete against it. also, is it just me, or are you running the moab's backwards? | |
10-14-2006, 12:30 PM | #33 |
Well I had my 1st break I was going up steep incline with the rear hopping when my lousy tac welds broke free on the rear tranny output. While I had it taken apart I took some pictures of the Stealth Tranny Mount for Bender's SW2 chassis using existing tranny holes. Mount is a 2" X 3" 1/4 inch Aluminum plate with few hole drilled. The new tac welds should hold fine now. Added some black paint to help prevent rust on the welds. Other than that little break, I'm very impressed with what it can climb. |
10-14-2006, 08:56 PM | #34 |
Just an FYI, thats not a B3 Stealth, thats an original Stealth tranny from an old gold tub RC10.
10-14-2006, 11:13 PM | #35 | |
10-15-2006, 12:16 AM | #36 |
Rock Crawler Join Date: Mar 2005 Location: Murrieta
thats that rock no one could get up with their supers. thas why i like tlts |
10-15-2006, 01:05 AM | #37 | |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
10-15-2006, 01:56 AM | #38 | |
10-15-2006, 06:06 PM | #39 | |||
I replaced the case with Associated Stealth Tranny Case #6565 http://www2.towerhobbies.com/cgi-bin...?&I=LX2859&P=7 Quote:
10-15-2006, 07:18 PM | #40 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
I didn't use those Fiber shims you gave us a link to in post #23 but I did use shims from disc brakes for a bicycle. They are the same width (.5mm) as the ones you posted. I started out using 1 shim per pinion gear and actually stripped out the rear ring and pinion after a while. I ended up putting 3 shims in per pinion (1.5mm of shimmage) and it seems a little tight, 2 shims per axle would be best. I just wanted the extra insurance that I wouldn't trash another ring and pinion |
