10-15-2006, 08:55 PM | #41 |
Pebble Pounder Join Date: Aug 2006 Location: Suffolk
I like the way you combined the outdrives, but I have a suggestion that may make it a bit more durable, and easily maintained. If you welded up the ends of the slots on the outdrives, then used a bolt or crosspin through the slot into hole on the U-joint shaft it would allow you to removed the U-joint from the outdrive, and would give you a slider of sorts. The other way you could close the ends of the outdrives would be to weld a piece of tube over the outside of the end of the outdrive, so the bolt or crosspin setup would not fall out. Just a couple ideas.
10-15-2006, 09:07 PM | #42 |
Here's a drawing, hope this helps make sense of my terminology. [/IMG] |
10-15-2006, 10:03 PM | #43 | |
Quarry Creeper Join Date: Oct 2005 Location: SoCal
When I first built the axles I didn't know they needed to be shimmed. So I ran them for about 2 hours with no shims. After several members brought it to my attention that it would be a good idea to shim them up, I took there advise and open the axles up. There was fine metal shavings inside already and you could see the wear on the gears. Just by the wear I could see on the gears told me where the shim would go. I still tried multiple shims and different shim placement to see what would work best. Using only ONE SHIM to push the ring gear in toward the pinion worked best for me. Last edited by Johnson420; 10-15-2006 at 10:25 PM. | |
10-15-2006, 10:22 PM | #44 | |
Also with the slipper on the Stealth I don't plan on having to take the tranny apart EVER. Well at least I hope I never have to take it apart because these welds aren't gonna break like the last ones did. | |
10-15-2006, 10:23 PM | #45 | |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Same here. Great lookin' rig. Only bad thing about black...scratches show very easily. Future floor wax won't remove scratches, but it'll hide'm for most pictures. | |
