02-06-2007, 07:32 PM | #41 |
Rock Crawler Join Date: Nov 2006 Location: Albuquerque
I like it man. I just dropped a Bronco lid on mine and love it. I am thinking about shortening the wheelbase from 12.5 to somewhere between 11.75 to 11.5 to keep the mashers from snagging the front fenders so much. It'll be a little extreme on the driveline angles though. I think the Revo shafts can take it, from what I've heard. I need to get some pics up soon.
06-16-2007, 12:22 PM | #42 |
Rock Crawler Join Date: Sep 2004 Location: South Orange County
ya defanitley that would look good i just wanted the little extra wheelbase for comps |
10-04-2007, 01:39 PM | #43 |
allright so im getting my rig more comp worthy i ditched the waterproof setup and went with a more comp type setup with the help of bender. esc mounted on the rear axle rx mounted on the top of the upper links in the rear.. messed around with shock oils and shock placement got a set of moabs finally and have a set of narrowed rims with some medium foams in them both thanks too grob23 tested this setup and i really liked it except i broke an axle c so now i want to buy the clocked axle c's and get my pinion angle better aswell as bend the lower links for more clearance but without hitting the driveshafts and the metal yokes too bad.. i'll get pictures when i get home but does this setup sound good what can be improved? waiting on axles c's and going to bend the lower link for more clearance and a need a new body |
05-27-2011, 10:56 AM | #44 | |
Pebble Pounder Join Date: May 2011 Location: Bettendorf, IA
***EDIT*** Sorry, I see at the bottom that you are switching to plasti-dip. Last edited by jammindriver; 05-27-2011 at 10:57 AM. Reason: Mistake | |
05-30-2011, 07:20 PM | #45 |
plasti dip all the way i used the same procedure on a different rig and it turned up awesome |
09-28-2011, 02:50 PM | #46 |
Newbie Join Date: Sep 2011 Location: Champaign
do you have to waterproof the esc if its in that box? or did you do that for extra protection? *edit* since the esc is going into the now waterproofed box |
