10-19-2006, 09:27 AM | #21 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
Here are the pics. I haven't been able to post any from my camera for a while now. finally got them.. Progress to date. In quick time, or all at one time. TRANNY half way mounted. |
10-19-2006, 09:29 AM | #22 | |
10-19-2006, 09:34 AM | #23 |
The tranny needs a mount for the lower area (normally the top of the tranny). I have to make the delrin skid and figure the shock locations then it's off to the powder coaters. The tranny mounted this way allows for the lowest weight. If I end up not liking it I'll re-do the entire bottom. If the tranny was mounted "normal" then I would be able to cut the height in half, I was debating for days on how I should mount the tranny, figured this way the drive shafts would be right in the middle. Right now its around 6" tall, a little to high for me but well see how it works out. |
10-19-2006, 10:16 AM | #24 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I like the position of the motor. But, it may make driveshaft angle too steep. You may have to clock the tranny more. Have you mocked it up with the axles yet to check driveshaft angle?
10-19-2006, 10:18 AM | #25 |
Not yet. The chassis is about 10 or 11" long so I have some room still for "tweeking". And this will be a belly scraper (maybe) when it's all said and done. I'll try a quick mock up at lunch.. Now I just need to rember where I left my axles. Thanks bender. |
10-19-2006, 10:24 AM | #26 |
A low ride height will definitely help. The few Stealth trannies I've seen have the Maxx or Revo yokes bored to slid over the trannies output shafts. Which seems to steepen the driveshaft angles. Although the Pede tranny is alot thicker around it's output shafts, so maybe it just appears that way.
10-19-2006, 10:29 AM | #27 |
I'm hoping it just appears that way. I like to use the pede sliders inside the output shaft instead of the revo yokes. I'll find a link on what I do with them. Thanks for the help, I needed it. I wasn't even to a point at worring about the drive shaft angles. EDIT: found a pic instead. |
10-19-2006, 04:03 PM | #28 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
that thing looks good DJ. cant wait to see it finished.
10-19-2006, 04:21 PM | #29 |
RCC Addict Join Date: Feb 2005 Location: Minnesota
Can't wait to see that thing as a roller. Any ideas on what tires you are going to use?
10-19-2006, 04:41 PM | #30 |
Here's a pic of the Pede tranny with 2.5 yokes installed. It measures about 2 5/8" from the ends of the yokes.
10-19-2006, 08:35 PM | #31 |
RCC Addict Join Date: Apr 2006 Location: Brighton
Is that a Associated stealth or a LOSI trans? Looks a little different than the stealths I've seen. Maybe an older model? I know Bender posted up the traxxas...just being curious. Damn nice looking tuber Double J!! |
10-19-2006, 08:46 PM | #32 |
I beleive this one is a XXX.
10-20-2006, 04:26 AM | #33 |
Quarry Creeper Join Date: Oct 2006 Location: wollongong, NSW, Australia
That looks nice doublej Shane |
10-23-2006, 09:09 AM | #34 |
this project is now DONE. I'll be droping it off at the coaters today. Here are the last of the pics till the color is on it. Thanks for all the comments on my design of a comp based tuber. There is also a pic of the driveline angle (mocked) so it looks pretty good. Not to bad of an angle if you ask me. these are in no order. Last edited by Double J; 10-23-2006 at 09:32 AM. |
10-23-2006, 11:52 AM | #35 |
Doesn't look to bad at all. That Driveline angle doesn't look to bad. Looks close thou.
10-23-2006, 05:42 PM | #36 |
Powder coater said it'd be ready later this week.
10-23-2006, 06:19 PM | #37 |
Pebble Pounder Join Date: Jan 2006 Location: Calgary Alberta Canada
This will be a neet truck but I hope you have made the skid really well because it will definetly drag on the ground.
10-23-2006, 06:59 PM | #38 | ||
10-23-2006, 09:22 PM | #39 |
Sweet, love the mock up's...what color is the powder coating gonna be? Love seeing a well lived in shop bench area. Looks like the mad scientist lab.
10-23-2006, 09:45 PM | #40 | |
Thanks. I'll let Revoster let you all know what color. He may want to wait till he puts it all togeather before the final showing. The work area makes me MAD, I like organization but it hasn't been that way for about 3 months. | |
