01-18-2005, 03:20 PM | #1 |
Newbie Join Date: Jan 2005
| triangulated links
i want to triangulate my upper links. the problem is i cant find a good mounting point or way to mount them. any ideas. those that have done this,is their a real benefit to doing this. p.s. horizon hobbies has the integy lathe motors in stock for $20.00 |
01-18-2005, 03:34 PM | #2 |
Say hello to my dactylion Join Date: Jun 2004 Location: On the Boat to Whore Island
| Re: triangulated links
What axles are you useing and YES! you need to triangulate your links...well at least either the tops or the bottoms... both if you want, but do one at least. With out triangulation you will get no lateral stiffness... Well there are other ways to set things up but to triangulate your top links at the axles is the most common and easyest way to have an effective crawler 4-bar linkage system.
01-18-2005, 03:36 PM | #3 |
Pebble Pounder Join Date: Nov 2004 Location: leesburg,va
ben aluminum up-over-and back down you servo so you have somthing like a cover and then mount your link-mounts onto it
