10-09-2006, 07:35 PM | #41 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
Sweet! I think if it fits on Ralph, It'll fit on Evil Bastard. |
10-09-2006, 07:53 PM | #42 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Just send EB to me...I'll find out for sure. |
10-09-2006, 08:52 PM | #43 | |
RCC Addict Join Date: Feb 2006 Location: Moku O Keawe
10-09-2006, 08:57 PM | #44 |
Heres the link to it on Ebay...Not nearly in the same shape but pretty "Cherry" none the less!! http://cgi.ebay.com/tube-rock-crawle...QQcmdZViewItem |
10-09-2006, 09:00 PM | #45 | |
Perhaps I should buy it back. Suspension needed some work, but it was still fun. | |
10-09-2006, 09:21 PM | #46 | |
RCC Addict Join Date: Jun 2004 Location: Bruiser Heaven!!!!
rich | |
10-09-2006, 09:58 PM | #47 | |
10-10-2006, 12:10 PM | #48 |
New axle parts arrived today! Axle-Cs from SlinkySam. (www.fat-rock.com) Now I can get the axles rebuilt tonight. |
10-10-2006, 06:49 PM | #49 |
Suprised they lasted so long without them. I got some from Xtreme for EB & the others. Wish I woulda known about Sam, woulda got some from him too. |
10-10-2006, 06:57 PM | #50 |
Sam's are thick and well made. I'm surprised that there hasn't been more info posted on them. |
10-10-2006, 07:01 PM | #51 |
Rock Crawler Join Date: Jul 2004 Location: Salt Lake
Those C hubs look really good! The other ones i've seen look pretty hacked. BTW I cant wait to see the finished result. Are you still planning on using all-t's?
10-10-2006, 07:10 PM | #52 |
Yup, I compared the two versions of Axle-Cs that were being made and Sam's were the obvious choice for a pig like Ralph. Yeah, the All-Ts in post #12 are new ones that are going on the rig. With Ralph's 14" wheelbase they're about the only tire that "looks right" once installed. The old ones are fine, I just didn't want to boil them off just yet. Might use them for basher tires. Sheldon, I snapped an axle housing on Ralph at UROC. 40ft tumbles will do that. I still have the old housings here somewhere. Last edited by JasonInAugusta; 10-10-2006 at 07:13 PM. |
10-10-2006, 07:21 PM | #53 |
Quarry Creeper Join Date: Mar 2006 Location: TAOS NM
Those look pretty beefy looks good jason cant wait till you get it done.
10-10-2006, 09:34 PM | #54 | |
10-10-2006, 09:39 PM | #55 | |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
10-10-2006, 09:43 PM | #56 | |
Yeah, Ralph is a fat pig. | |
10-11-2006, 02:21 AM | #57 |
Rear axle is almost wrapped up.
10-11-2006, 10:51 AM | #58 |
RCC Addict Join Date: May 2006 Location: Roseville
First time I have seen an installed picture of those C's... They look great!
10-11-2006, 12:22 PM | #59 |
Quarry Creeper Join Date: Aug 2004
Jason, I got to ask about the all-t tires....... I have set from the first production run and I finally cut them and got them to hook up okay. But I have been having wheel bounce issues since the last g2g i ran them at..And I am not sure why....How did you cut your foams? I am running half masher 2k foams.. And that Tuber is very cool! Love the nice beasts you build and run! |
10-11-2006, 12:34 PM | #60 |
Ron, Thanks. I'm running double-narrowed wheels. Install the tires/foams onto the stock width wheels and let'm sit for a day or so. Then yank the tires and foams off, then remove the foams. You'll see where the inner bead has left indented rings in the foams. Just take a knife and cut from the outside corner of the foam towards that indent from the inner bead of the wheel. The resulting foam you remove will look like a conical washer. I do this on each side of the foam. Then narrow your wheels, install the foams in the tires, then mount the tires on the wheels This gives me a full diameter foam that should work well. Have yet to test'm. I ran some BBs in the front tires on Ralph before, might just go with stick on lead weight inside the front wheels this time around. But with the BBs I had to reduce the diameter of the foams and felt that it left the tire a bit too soft. We'll see how the new foams work out. |
