Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Real time Courier build
Old 12-06-2006, 10:24 PM   #61
Nice. Good body choice.
Wait till you get to abstract algebra.
MATH 613. Abstract Algebra. 3 hours. Elements of group theory and ring theory; subgroups, cyclic and permutation groups, homomorphisms, quotient groups, isomorphism theorems, subrings, and ideals. Applications to modular arithmetic, partitions and equivalence relations, polynomial rings, complex numbers, integral domains, and fields. Prerequisite: MATH 617 Linear Algebra or MATH 513 Discrete Structures.
Now that's fun!
1tom2go is offline   Reply With Quote
Old 12-07-2006, 08:36 AM   #62
looks great, hopefully you can get youur motor in there, it will be tight, may have to loosen some things up to get her in there. Great job so far!
Rc EnthuSiasTs is offline   Reply With Quote
Old 12-07-2006, 02:12 PM   #63
December 6
9 pm
decided to use pede shafts now smaller and more to scale with the rest of the truck the maxxes were too big and limited travel there goes another 15
shafts 10
yoke 5
extended them and they do slide
1.1 sport trac is offline   Reply With Quote
Old 12-07-2006, 03:40 PM   #64
Poser shots cant wait to get this done!!!
Old 12-07-2006, 05:59 PM   #65
Nice dude. Gota love those blingin wheels in the last pict. Nice build
west virginia krawler is offline   Reply With Quote
Old 12-07-2006, 06:09 PM   #66
bling bling chaching, nice caddy ya gots there, ext?
halfcab is offline   Reply With Quote
Old 12-07-2006, 06:18 PM   #67
my moms escalde 07 its nice lol
Old 12-07-2006, 06:21 PM   #68
December 7
8.23 pm
got my drive shafts installed
but it feels like there is a bind is this normal for crawlers because i have to push it to roll and as soon as i stop it doesnt keep rolling?
Old 12-07-2006, 07:12 PM   #69
any motor in it? all the gear reduction keeps it from freewheeling, always kind of feels like it is under load if the motor is in it
Old 12-07-2006, 07:16 PM   #70
alright thanks it had a motor i got it one of the shafts was binding
9 pm
put some crap electronics in it and drove around i noticed i need tooo....
soften up the suspension lighter oil
reword steering
lathe motor
buy a stick pack cause a side by side pack isnt gonna work
Old 12-16-2006, 04:45 PM   #71
Saturday December 16
Had to cut the fenders off the courier body all i need now is a
lather motor 45 or 55?
stick pack
Old 12-17-2006, 08:12 AM   #72
Are those maxx shockx with stock red springs? If they are you will need softer springs. Losi yellows in the front. And somthing slightly stiffer in the rear. Run the rear stiffer than the front. This setup works well on my SW2.
I would go with the 45t lathe motor. The wheel speed will come in handy to get over obstacles. In my SW2 the 45 seemed to work well. A good balance between wheel speed and torque. You may need to mess with your gearing a little.
For batteries I run the smaller 2/3a cells. Same as a mini-t pack. I actually run a 6 cell side by side setup. I mount it to the top of my steering servo. It is shrink wraped of course. But it seems to work well with plenty of run time. Just another idea for you.
The truck is looking good. Hope you make it out to a few of the Carolina Rock Runners gatherings next summer.
BrandO is offline   Reply With Quote
Old 12-17-2006, 06:04 PM   #73
ya i am gonna change the springs out. Hopefully ill make it to a few get togethers
Old 12-17-2006, 11:16 PM   #74
Thanks for the thread, I'm looking into getting started and doing almost the exact same thing that you've done. But probably on a much slower scale. Great pictures and explanations, thanks again ..
joemomma95 is offline   Reply With Quote
Old 01-12-2007, 05:54 PM   #75
well my crawler build is still in progress it was just put on hold for a while i will update when i get the rest of my parts in sorry guys
Old 01-12-2007, 05:58 PM   #76
Default extension
Originally Posted by 1.1 sport trac
December 6
9 pm
shafts 10
yoke 5
what is your wb ? ? ?
why did you extend them ? ? ?
chivas72 is offline   Reply With Quote
Old 01-12-2007, 07:40 PM   #77
u need to lengthen them to the them to fit.
iwantoffroad is offline   Reply With Quote
Old 01-12-2007, 08:21 PM   #78
I joined the Band!
sweet, what grade you in?
Bronco is offline   Reply With Quote
Old 01-13-2007, 07:15 PM   #79
my wheel base is around 12 in or a little less
i extended the shafts because with stock length there is too much play in between the two shafts
iam in 10th
Old 02-26-2007, 04:24 PM   #80
2/26/07 6:27 pm
well the truck is done except all i need is a lathe motor will get photos up in a few hours
