01-25-2005, 09:37 AM | #1 |
Quarry Creeper Join Date: Dec 2004
| Project Immolator -- Update 1/26
Here' my scale trail rig so far... when it's finished I'll take more detailed pics but so far... Custom stuff for axles -alum servo mount -alum blocks to convert to coil suspension -alum over the servo top link mounts -custom solid links with rear lockout Tranny -locked -alum idler -Made a alum plate to cover the gear/mounting point, and made a mounting point for the other side of the tranny with some L-stock alum. still have a lot more to do....links, bottom link/shock mounts for axles, mount all the ESC, receiver, tranny, and batts, and maybe a winch. it's a rough mock-up but you get a good idea of what it will look like later Last edited by sicj; 01-26-2005 at 06:26 PM. Reason: Project Update |
01-25-2005, 09:42 AM | #2 |
Rock Stacker Join Date: Dec 2004 Location: Hillsboro, oregon
looks pretty good to me, how long do think it will be till youre gonna finish?
01-25-2005, 01:04 PM | #3 |
Quarry Creeper Join Date: May 2004
thats sick dude, cant wait till its done
01-25-2005, 05:28 PM | #4 |
thanks, it should be done within 1-2 weeks
01-26-2005, 06:26 PM | #5 |
--1/26 UPDATE-- Got the side plates and tranny mounted today |
01-26-2005, 06:38 PM | #6 |
Quarry Creeper Join Date: Nov 2004 Location: In the saddle...
Those wheels are really familiar, what are they?
01-26-2005, 06:51 PM | #7 |
Rock Crawler Join Date: Jan 2004 Location: Santa Cruz, CA
Looking good man |
01-26-2005, 07:02 PM | #8 |
the wheels are RPM Torkers... I narrowed them on the inside bead. This thing is getting heavy already but it's better having it overbuilt. |
01-27-2005, 08:41 PM | #9 |
Rock Stacker Join Date: Dec 2004 Location: Concord California
very cool looking, may i ask where you got the aluminum??? Thanks -Dan |
01-28-2005, 08:59 AM | #10 |
all the alum. was bought at onlinemetals.com except for the L-angle channel, that was bought from mcmaster.com
01-28-2005, 09:17 AM | #11 |
Quarry Creeper Join Date: Jan 2005 Location: Milan, Italy
Looks good. Is it a pede tranny, isn't it? |
01-29-2005, 05:40 PM | #12 |
-- 1/29 Update -- 4 link finished and front suspension mounted. Still need to hang the rear springs and mount all the shocks and the suspension will be done. |
01-30-2005, 11:23 AM | #13 |
some articulation shots... the rear springs are zip-tied in these shots and the shocks aren't mounted, but I'm expecting the same amount of flex with everything mounted. |
02-09-2005, 08:38 PM | #14 |
-UPDATE- Well got it done and how I think I'll leave it for the time being.... I changed the batt. to where it is int the pics, I originally had them mounted at the side plates as a saddle pack and it just made the chassis too wide and it really didn't climb to well (compared to what I see in the Oregon dudes vids)....now with the batt. up front it climbs WAAAY better, much more traction. Only thing I think I'll change is how the side plates widen near the top, when desining the chassis I figured the links would mout up there, well it didn't turn out that was (links would be too short) so I'll trim those off. All I need to do is disassemble, probably paint all the alum. flat black, paint up my Chevy body and make a 2nd pack and it's all good. so fun to see it start out as jack shit and turn into something. RC Electric and crawling are 2 completly new things to me and learing how everything works was awesome and to see it all work together is even better. |
02-10-2005, 07:20 AM | #15 |
Seems to pčerform well what body will be added? |
02-10-2005, 07:46 AM | #16 |
I'll be running a new Parma Clody body, like the one in the first post when I did the mockup
02-10-2005, 10:18 AM | #17 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
Have you had any driveline issues? I mad a double female shaft for my buggy because they are about as long or longer than yours.
02-10-2005, 10:43 AM | #18 |
no, no problems. Those are stock pede sliders, there is about a 3/4" - 1" in the male shaft.
02-11-2005, 04:02 AM | #19 | |
02-12-2005, 07:02 PM | #20 |
-UPDATE- Finally got my Parma Clod body trimed, painted, and decaled. Also dyed the rims black, and took out the tire foams. Final Specs: -Clearances- wheelbase: 11 3/8" center: 2 5/8" axle: 1 1/2" trace width: 10" length: 17 1/8" -Parts- -Fully custom chassis -Dual Triangulated 4 link (HPI rod ends. Drilled and tapped, no wussy sleeving threaded rod) -Plexi Glass center skid -Coil Sprung suspension (thanks to Grizzly for the idea) HPI Rush rear springs with HPI MT2 shocks -Hitec 645 MG (no servo saver) -Kyosho Mag Mayhem Motor (with Traxxas heat sink) -DuraTrax Intellispeed 16T ESC -Hitec Receiver -Custom built 3000maH battery packs (Deans Connectors) -Pede Tranny (locked, trimmed, no slipper) -TLT axles (locked and full ball bearings) -Pede telescoping drivelines with steel yokes -RPM Torkerz Wheels (Dyed Black) -Imex 2.2 Swamp Dawgs (no foams) -Parma Clod body with custom decals Last edited by sicj; 02-12-2005 at 07:26 PM. |
