01-06-2007, 05:29 PM | #61 |
Quarry Creeper Join Date: Jan 2006 Location: San Diego
Looks perty I have same body on my rig.
01-06-2007, 09:48 PM | #62 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Lookin' good! That body is like camera flashes at a sports event or concert. Walk past it and it just sparkles. Can't wait to see it in action this coming weekend. |
01-06-2007, 11:53 PM | #63 |
Rock Crawler Join Date: Jan 2007 Location: Long Island NY
thats one real clean build after reading this thread and seeing the detail on the shafts for the trans im not so confused |
01-07-2007, 08:20 AM | #64 |
Quarry Creeper Join Date: Dec 2005 Location: NH
you got an underside shot? I just picked up two of these chassis's and Im looking around to see how people set them up. Looks great so far man! |
01-07-2007, 09:51 AM | #65 | ||
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
By jeckler at 2012-05-04 In order to avoid cutting down the body to much, or raising it to stupid levels off the frame, I had to restrict the shock travel. Each shaft has 15mm of fuel tubing on it. I still get a little over 4 inches under the wheel, and a little more when the tubing is compressed. So each shock has about 5mm of stroke. So this might be more of a scale truck than initially planned. Last edited by Jeckler; 05-04-2012 at 08:49 PM. | ||
01-15-2007, 12:22 PM | #66 |
Quarry Creeper Join Date: Dec 2004 Location: Croydon, Surrey, UK
im well into my K2 build as well now, its a beautiful chassis and with the msd servo plates i got, is starting to look good. Im kinda going semi scale with carson wheels and tyres from my old nitro truck (Carson is a German make many of you guys wont have heard of. The MadRat is identical chassis to your XTM blade). Im using 3mm threaded bar through 2 sizes of brass tubing. My bottom links to the same length as in Kaetwos build doc each weigh 14grams (is that too heavy for links?)I had to cut down the Range rover bodyshell i was ggonna use as the rear wheel arches were way out of linf, so i flat bedded it and now there are no rear arches to worry about, i will try and get some pics for you all to see, but not having a computer or digi cam ill have to beg and borrow
01-17-2007, 09:10 PM | #67 |
Newbie Join Date: Sep 2006 Location: chino hills
just wondering why one spring is green and the others are white lol. also how far can you lift one tire with out the others going off the ground with out the fuel line in the shocks? |
01-17-2007, 09:15 PM | #68 |
Rock Crawler Join Date: Jun 2006 Location: Santa Rosa
the back left suspenison suffers from torque twist, due to the torque from the motor twisting the axles, so they use a stiffer spring in the back left to keep the chassis from twisting!
01-18-2007, 09:06 AM | #69 |
Yep, heavier spring in the left rear, along with some 50wt oil. 30wt in the other 3. Without the fuel tubing on the shocks, I was getting 6 inches of clearance under the wheel before any other lifted. I'm *still* waiting for some decent weather so I can get a couple pics of it outside. Clouds aren't helping. So far I've seen pretty much how slow it goes. I'm thinking of dropping an Orion Core Stock in it and see how fast it'll go. |
05-07-2007, 05:43 PM | #70 |
Pebble Pounder Join Date: Aug 2006 Location: port angeles
sweet build i like those wheels they go good with that color of body
