MIP cvd's Can they be modded to run with 1.9 wheels? I just bought a set of axles and they got em,metal c hubs and aluminum knuckles. I'd like to put hopped up axle on my 1.9 f350 |
Re: MIP cvd's What wheels do you have? Usually just drill the axle opening to fit the mip through on 2.2s. Not scale looking as you need to use a spacer to make it work. Or I have shaved the axle down to the hex, then you need to cut the bolt down to size. You loose quite a bit of contact threads, but with locktite I haven't had any problems with loosening. |
