11-29-2006, 04:26 PM | #1 |
Rock Stacker Join Date: Jan 2005 Location: Toledo
| BB lockers
Stick 3 regular bb's inbetween each spider gear in your diff and its locked.
11-29-2006, 04:33 PM | #2 |
RCC Addict Join Date: Jul 2005 Location: Provo
interesting that may be a good idea to do if you do the spider gear trick put some in there to keep starshaft from breaking...interesting idea |
11-29-2006, 04:45 PM | #3 |
Rock Crawler Join Date: Jan 2006 Location: Connecticut
Pics??
11-29-2006, 08:49 PM | #4 |
Um..... I seriously don't feel like taking and posting a pic. Just put all your gears in then cram in as many bbs as you can fit and then stick it together. I tried to spin the axles with my hands and it seems pretty locked, however when the bbs get in just the right spot it will slip just a tiny bit. I think over time it will eat away at the bbs or gears or both. But if that happens then I'll just JB it. |
11-29-2006, 09:41 PM | #5 |
Quarry Creeper Join Date: Oct 2004 Location: illinois
I don't think your gears will like those bb's for very long.
11-30-2006, 08:07 AM | #6 | |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
matt cincy | |
11-30-2006, 09:07 AM | #7 | |
Pebble Pounder Join Date: Aug 2006 Location: B.C. Canada
Whats wrong with JB? | |
11-30-2006, 09:27 AM | #8 |
the only thing I am can think of is the fact that it is not reversiable; I do not see a need or desire to reverse it true, but I would like the option if there is ever a better way developed. matt cincy |
11-30-2006, 09:30 AM | #9 | |
RCC Addict Join Date: Nov 2004 Location: Redding, CA
11-30-2006, 03:18 PM | #10 |
what about those ultrasonic airsoft bb's? matt cincy |
11-30-2006, 04:07 PM | #11 | |
The best thing I could think of to use that is reversible would be small pieces of hard metal in various sizes, so that it can get inbetween the teeth and prevent them from moving. With the bb's only the very edge of the gears are touching the bb's. I have driven it in my room on carpet (high traction surface) and some bricks with 4ws for about an hour with no problems yet. | |
11-30-2006, 09:00 PM | #12 |
Newbie Join Date: Nov 2005 Location: sammamish
actually the easiest way and mmost reversable way is hot glue. it gives jsut a little bit and helps prevent the axles snapping to some extents but also even when locking the my own diffs I messed up once it was cool I could just rip it out and do it again. it works awsome.
11-30-2006, 09:09 PM | #13 |
will hot glue hold up to a BL motor setup running through a R2 trans? seems like it would be a weak link in the system- maybe a good thing; keep s**t from breaking. matt cincy |
11-30-2006, 10:28 PM | #14 |
BB's are waaay stronger than those crappy gears.
11-30-2006, 11:22 PM | #15 |
Why not just JB weld it. Who cares if you can't reverse it. It's a few bucks to replace it. Anyway why in the hell would you want to undo it? It's a crawler and thats what it will always be. Just my thoughts...But what do I know.
12-01-2006, 05:37 PM | #16 |
Newbie Join Date: Feb 2006 Location: West salem
stuff the entire case with steel wool.
12-01-2006, 06:13 PM | #17 |
Rock Crawler Join Date: Jan 2006 Location: In the basement
I just did the spider gear swap, I'm going to stick with that untill something breaks in there. I don't think the potmetal will hold aginst the bb's. |
