12-01-2006, 04:14 AM | #1 |
Newbie Join Date: Feb 2006 Location: West salem
| "Fer Cheap" crawler build
Ive been scouring the net for deals and I think I have pieces enough to start assembling DON Last edited by Mr Badwrench; 12-01-2006 at 04:19 AM. |
12-12-2006, 03:27 PM | #2 |
| getting some work done.
Ok... Transmission $7 Brushless outrunner $17 MGT A-Arms $7.50 various nut bolts and washers $2 |
12-12-2006, 03:30 PM | #3 |
After I assembled my chassis for the first time I got an idea that I need to share. Using 6 shocks instead of 4.. 2 being somehting short and cheap... use MGT or MAXX lowers instead of uppers and using the stock shock mount on them to put a single shock in the middle this would give you your height without even efecting articulation at all. sorta like how a stick crawler works This would make My chassis Much much narrower which I dont see that as a bad thing... just thinking out loud. |
12-12-2006, 04:35 PM | #4 |
Rock Crawler Join Date: Jun 2006 Location: Santa Rosa
Good find on the parts. Great deal on the tranny! Will keep an eye on this build |
12-12-2006, 10:49 PM | #5 |
Quarry Creeper Join Date: Nov 2006 Location: Lexington Park
where did you get the motor? and how do you know if it will work for crawling before you buy it? thanks.
12-13-2006, 04:20 AM | #6 |
unitedhobbies.com and I dont know if it will work... but its a motor it was cheap and ill just keep adding gears untill it does work. DON |
12-13-2006, 08:59 AM | #7 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
That transmission looks beefy. Nice find for 7 bucks. As long as it will fit a big enough spur and small enough pinion, should be ok...
12-13-2006, 11:30 AM | #8 |
What is that trans out of?
12-13-2006, 01:53 PM | #9 |
the Transmission is out of a toy tank.. I found them online as complete trannys or just a metal gearset I just bought 2 more from Mato Toys International...So I have 3 currently. Right now they have them listed for $15 for 2 of them including a brushed 380 or385 motor (never looked) Plus they have just the metal gears for $8.43 You could make your own gearbox (my original plan) using the gears and have any amount of reduction you want. DON |
12-22-2006, 04:54 PM | #10 |
12-22-2006, 05:04 PM | #11 |
Pebble Pounder Join Date: Oct 2006 Location: Honeoye Falls, NY
picture no workey. but that red x is quite the revoulationary idea! |
12-22-2006, 10:04 PM | #12 |
Transmission $7 Brushless outrunner $17 MGT A-Arms $7.50 various nut bolts and washers $2 3/16 brake line $3.99 (plan on reinforcing it with 1/4 hopefully before I break one) duratrax kingpins for nitro quake $7.99 '' '' '' Ball ends "" "" "" $4.49 used traxxas sledgehamemr wheels $20 for 4 with lame tires Geolanders $30 uninstalled, want to narrow rims Last edited by Mr Badwrench; 12-23-2006 at 05:51 PM. |
12-23-2006, 05:38 PM | #13 |
12-23-2006, 05:41 PM | #14 |
12-24-2006, 08:34 AM | #15 |
I joined the Band! Join Date: Sep 2006 Location: ...
looks good. any updates? |
01-01-2007, 07:34 PM | #16 |
| WOW, all the way from page 5 |
01-02-2007, 09:54 AM | #17 |
how do you like the 3-link?
01-02-2007, 06:02 PM | #18 |
| 3link
I would not have it any other way... there is zero side movement no matter what you are doing. Im actually considering mounting a servo in the chassis to see if I cna get away with it.
01-04-2007, 08:47 PM | #19 |
Rock Stacker Join Date: Nov 2006 Location: Tulsa
How does the transmission work for you? What pitch are the gears? Would it be easy to find a pinion if I just purchase the gears is what I really want to know. Sorry for all the questions.... I am considering buying from them as well for my custom chassis build. I think these gears can be re-arranged and used to build a compact gear box.
01-05-2007, 07:27 AM | #20 |
Yes, Im sure the gears can be rearanged. be carefull they are POT metal and do not react well to heat, when I made my outdrive I melted one gear trying to solder it to the new shaft... I indended to do so, but got lazy. The output gear rides on a 5mm shaft which I replacesd by using the bushing from a second transmission and a longer shaft with Ds cut in both ends. I am using a 48p pinion But I do get a slight gear whine that I actually like but It does mean that the gears might be metric. Its close enough for me though. Got my savage shocks yesterday Last edited by Mr Badwrench; 01-05-2007 at 07:30 AM. |
