12-09-2006, 02:18 PM | #1 |
Rock Stacker Join Date: Apr 2004 Location: Bamberg / Germany
| A little Revolution? Clod-like TLT Stick-crawler
Hi! Yeah you´ve read wright: A "real" stick with TLT-axles... Click pic 4 gallery! It´s an old idea of mine and now I´m building it. It´s looking "rugged" but it has to be in that way - I´ve got no CNC or something like that, only a drilling machine and a set of tools... Tomorrow I´ll hopefully can finish the second axle. Then there are only the links, body- and shock-mounts and some wireing left for finish this little project! I´m looking forward the first drive... Technical stuff: Wheelbase aprox. something about 33cm (13 inch). The weight is projected to aprox. 2900g (4,41lb) with everything included. Wheels are gonna be the Proline Masher 2000... I´ll keep you updated... Manuel |
12-09-2006, 02:51 PM | #2 |
Pebble Pounder Join Date: Oct 2006 Location: under a rock
man that looks sweet,great idea |
12-09-2006, 02:52 PM | #3 |
Pebble Pounder Join Date: Sep 2006 Location: SW Charlotte
yeah looks very good
12-09-2006, 03:02 PM | #4 |
Neat idea. But it has less ground clearance already without the links on it.
12-09-2006, 03:05 PM | #5 | |
@traylor4x4 & roadblock Thanks! Manuel | |
12-09-2006, 03:30 PM | #6 |
Pebble Pounder Join Date: Feb 2006 Location: the race track
What did u use to mount your motro? it doest look like a tranny i may be wrong.
12-09-2006, 09:14 PM | #7 |
Pebble Pounder Join Date: Apr 2006 Location: griswold
Loving the direct drive!
12-09-2006, 09:30 PM | #8 |
Quarry Creeper Join Date: Dec 2005 Location: Winston Salem
its a cool idea, but why not just build a clod?
12-09-2006, 11:21 PM | #9 | |
@mudhunter It´s a geared motor, I´m using the two theads in the gearbox to mount the whole motor... Manuel | |
12-28-2006, 02:44 PM | #10 |
Hi folks! Worked a little bit before Christmas. Finally here are the pics: Click pic 4 gallery! Looks different from what I had planned at the beginning but still interesting. The geared motors are fantastic, they got tons of power. Great control at the throttle and massiv holding power at stops in the hill. The first driveout in free nature ist still standing out - and it´s currently freezing cold out there... :-( Manuel PS: Anyone got tips for the problem in picture 17? |
12-28-2006, 03:08 PM | #11 |
Quarry Creeper Join Date: Dec 2006 Location: Finland
Really nice and clean, thought it looks heavy too.
12-28-2006, 03:12 PM | #12 |
Rock Crawler Join Date: Jul 2004 Location: Mt.View CA
Clean fab work, but to bulky IMO. the GC seems to be really hinderd with the motor setup. And it seems like the edges of rocks good get lodged in between the motor's. seem's like you could you mount the motor's up by the top rail and clock the axles so the drive shafts are arn't at a extreme angle, you would clear up some space in between the axles and get more GC. Just my .2 cent's As far as pic 17 » Fat-Rock « Axle-Cs this should solve it. Last edited by bigred; 12-28-2006 at 03:18 PM. |
12-28-2006, 03:22 PM | #13 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
Nice looking. But the motor's mounted that way will get you hung up real good. I'd try to mount the motors ont he axlse or off the stick somehow to get them out of the way of the rocks. Maybe a combo of gears going straight down to the output on the axles. Or even the motors mounted off the belly of the stick at least the shafts will slide on the rocks. |
12-28-2006, 03:25 PM | #14 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
There have been a few builds of max based stick rigs that were similar to this. They used 'pede trannys for each axle if I recall correctly. Cloak and Johnrobholmes, if I recall correctly. |
12-28-2006, 03:56 PM | #15 | |
pic 17 problem, got to www.fat-rock.com and buy their axle c's, that will fix it. They are great to deal with and make a quality product. | |
12-28-2006, 06:52 PM | #16 |
Pebble Pounder Join Date: Aug 2006 Location: Suffolk
Why not just mount the motor directly to each axle with the gear reduction turning an intermediate shaft and gear setup to then turn the pinion. The motor could sit to one side of the pumpkin, and be tucked up out of harms way, the only snag would be steering servos...
12-28-2006, 06:56 PM | #17 |
Rock Crawler Join Date: Oct 2005 Location: Clarkston, MI
Once the clocking axle Cs come out, you can mount the motors vertically on top of the axle. I think that will start a revolution. Unless the clocking Cs have come out already.
