02-02-2005, 11:22 AM | #1 |
Pebble Pounder Join Date: Oct 2004 Location: ny
| scale blazer project in the works...
i realy want a scale wrangler or blazer ... but i realy have no money ... but i do have a tamiya c-10 (independent suspention) so i decided to use that make it a solid axel and make a scale crawler.. hears my starting point.. Last edited by chaos18; 02-04-2005 at 05:43 PM. |
02-02-2005, 11:25 AM | #2 |
02-02-2005, 11:44 AM | #3 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
Sweet. Looks like its going to be alot of work. I take it you didn't want to just settle for bruiser axles then? Keep us posted.
02-02-2005, 12:11 PM | #4 |
02-02-2005, 12:25 PM | #5 |
I thought it was going to be a wrangler???
02-02-2005, 06:40 PM | #6 |
02-02-2005, 06:58 PM | #7 |
Rock Crawler Join Date: Feb 2004 Location: The Gay NorthWest
HEY NOT TO BE AN ASS HOLE. BUT YOUR AXLES WONT WORK, AND PERSONALLY I DONT THINK THEY LOOK VERY GOOD.... ZIP TIED TOGETHER??? oops sry caps on anyway, they wont work because, it looks like ur going to take the pinion gear and stick it between to big diff gears am i right??? well if you do that, one tire will spin one way and the other the other way.... and the blower on the hood looks go awfull ryan |
02-02-2005, 07:11 PM | #8 |
im not stupid theres ony one diff gear and i locked it like a spool..and if you would have read my post you will see that i said i was going to soder it... Chaos |
02-02-2005, 09:22 PM | #9 |
RCC Addict Join Date: Nov 2004 Location: Redding, CA
um i dowt the solder will even hold unless its a shelf queen . you should just get your self some bruiser axels and save your self the hasle Last edited by mike; 02-03-2005 at 03:56 PM. |
02-03-2005, 02:50 AM | #10 |
Rock Stacker Join Date: Dec 2004 Location: in limbo
give the guy a hand. better than most of you people that dont even have a rig or know the first thing about driving one. i think this guy has a awsome idea. are you going to get a bearing to fit the i.d. if the pipe and then the driveshaft? |
02-03-2005, 08:30 AM | #11 |
Quarry Creeper Join Date: Jan 2005 Location: Milan, Italy
Sure there will be a TON of custom work here ;) Keep us posted. |
02-03-2005, 02:35 PM | #12 |
well mike if you knew anything about plumbing you would know that im not talking about a sodering iron... you use a torch to melt the soder.. and thats the reason im using copper....and i dont want brusier axels im not like every one esle who just buys there crawlers (im not nockin you real crawlers out there) im sure you all know the feeling of bulding your first crawler and watching it go through its first run... well i want it to be like that except i dont want to go out and buy my axels..... and about the bearing i took a nut and hammered it into the pipe then drilled it out to fit the bearing... and thanks for your support.... Chaos |
02-03-2005, 03:59 PM | #13 |
i acually do know about soldering copper, since we redid the pluming at my house last summer, and it is pritty strong. sorry for assuming your useing a soldering iron. :-| oh, and "solder" isnt spelt "soder" |
02-03-2005, 04:23 PM | #14 |
Rock Crawler Join Date: Jan 2005 Location: Bethlehem, GA
I say if you can pull it off then do and post pics. I understand what you are sayin about the copper pipe. i once attempted making a 1/4 crawler from Copper Pipe and a bunch other parts shown here. http://www.rcpics.net/media/Im000143.jpg http://www.rcpics.net/media/sm-1_4_scale_wheels.jpg http://www.rcpics.net/media/sm-Bearing_Carriers.jpg http://www.rcpics.net/media/sm-Bearing_Carriers1.jpg |
02-03-2005, 04:42 PM | #15 |
thanks your pics dont work though... but i think ive seen it around before.....im gonna solder**** them tommrow and hopefully get closer to finishing the front axel. i just have to fugure out what to do where the diff is... Chaos |
02-03-2005, 04:52 PM | #16 |
You should edit the title to say blazer instead of wrangler |
02-03-2005, 07:12 PM | #17 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
Are the metal pieces connecting the knuckle to the tubes made of aluminum? You cant solder aluminum, can you?
02-04-2005, 05:41 PM | #18 |
you can solder alum..... to alum but not to copper ..... no i mad diffrent peices out of copper to solder on. Chaos Last edited by chaos18; 02-04-2005 at 05:44 PM. |
02-04-2005, 07:45 PM | #19 | |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Opps-sorry, I'm a dumbass and I'm to lazy to use the backspace key convienently located in the upper right hand corner of my keyboard! By the way-you suck at being an asshole, asshole | |
02-05-2005, 09:37 PM | #20 |
