12-13-2006, 03:57 PM | #1 |
Pebble Pounder Join Date: Oct 2006 Location: Right Coast
| Rubbing issue with Junfac links
I replaced the 80+ T stock spur gear on my TLT with a Traxxas 72T spur gear. The gear is slightly larger than the stock one, and I already had to cut some space on my chassis to make it fit. (the opening for the spur gear.) Now here is my problem, when I add the upper end links the ball hits the spur gear. I already trimmed the end ball so it's flat on one side, but with suspension travel, it still hits the spur gear. What can I do to fix this problem? Has anyone encountered this?> |
12-13-2006, 04:24 PM | #2 | |
Quarry Creeper Join Date: Oct 2006 Location: Bland
try using this spur gear its a perfect match http://www2.towerhobbies.com/cgi-bin...2&I=LXN206&P=K and this pinion http://www2.towerhobbies.com/cgi-bin...2&I=LXEX11&P=K you have to take a dremel and trim the tranny for the motor to slide over and th gears to mesh correctly | |
12-13-2006, 04:35 PM | #3 |
That's too many teeth. I want 72T spur and 12T pinion. ** Seem like this is the only 72T one I could find, and it's only 39mm, almost 11mm less than the stock tlt one, so will I have any problems with this one? http://www2.towerhobbies.com/cgi-bin...?&I=LXPA04&P=7 Last edited by GraTou; 12-13-2006 at 04:39 PM. |
12-13-2006, 04:41 PM | #4 | |
why to many teeth??? what pitch are you using | |
12-13-2006, 04:44 PM | #5 | |
and 48pitch with the associated spur | |
12-13-2006, 04:47 PM | #6 | |
why 72 and 12 crawlers are built to hmm..... CRAWL | |
12-13-2006, 04:52 PM | #7 |
I thought 72 and 12 is good for crawling, well someone told me that. So I must go higher? Like what? |
12-13-2006, 04:55 PM | #8 | |
i had the two gears i suggested w/ stock tranny it worked great | |
12-13-2006, 05:03 PM | #9 |
Thanks m8. Anyone else have inputs? |
12-13-2006, 08:43 PM | #10 |
Quarry Creeper Join Date: Jul 2006 Location: Las Cruces, NM
I ran 83T spur to 13 pinion. It was fine, no problems....well, with the gears.
12-14-2006, 06:05 PM | #11 | |
Quarry Creeper Join Date: Apr 2004 Location: west sacramento
same here | |
12-14-2006, 06:26 PM | #12 | |
RCC Addict Join Date: May 2005 Location: I live Here
| ??????? Quote:
am i wrong ? ? ? sorry my bad read to fast | |
