Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: ........Inspired TORSION STICK...........
Old 07-09-2006, 05:45 PM   #1
Talking ........Inspired TORSION STICK...........
I owe Del Monte for getting the idea in my head after seeing the video of his.
I fixed the articulation problem. Had to move a whole bunch of things aroun to get it but it came at very unique.
Cole82 is offline   Reply With Quote
Old 07-09-2006, 05:56 PM   #2
holy crap i love it.
maybe i should start building comp chassis
peej410 is offline   Reply With Quote
Old 07-09-2006, 06:20 PM   #3
Y-Town Crawlers
Del Monte's Avatar
looks great!
I like the idea of the slanted backbone, it'll be interesting to see how it works.
Del Monte is offline   Reply With Quote
Old 07-09-2006, 06:29 PM   #4
it just looks so wrong, what were you drinking to come up with that?
Crawlsalot is offline   Reply With Quote
Old 07-09-2006, 06:57 PM   #5
Hell ya bitch.
This thing CRAWLS. I'm excited it's debute on real rocks will be this weekend. I'm going to the LHS tomorrow to pick up some small batteries. Then I can put them where I need to. Even with the battery up high it's still a low cg.
Here are pics from my yard.
Old 07-09-2006, 07:09 PM   #6
I just went and weighed it 4.7# with 3300 and a lathe. Allso water filled tires. I used them to play in the mud earlier.
So when the brushless gets back in this truck that's good for about 4.oz. The small battery is good for about 8+oz I should break the 4# mark easy.
Old 07-09-2006, 07:33 PM   #7
Nope..
Brainstain's Avatar
Originally Posted by dezfan
Now that is stupid simple at it best!, I love it.
So stupid simple I don't see how it's attached or how it works.
Brainstain is offline   Reply With Quote
Old 07-09-2006, 07:41 PM   #8
Thanks for the sapport guys.
Pics of the mounting to the axles. IT's mounted to the stock tlt double shock link mount thing.
Old 07-09-2006, 08:00 PM   #9
Y-Town Crawlers
Del Monte's Avatar
the torsion stick crawls nice doesn't it?
I'm liking the use of stock mounts too, I might have to try that instead.
Old 07-09-2006, 08:02 PM   #10
My shaft rust from lack of use.
Yes it does.
When it's off set like that it has more leverage to twist the c channel.=more articulation
Old 07-09-2006, 08:09 PM   #11
Nope..
Brainstain's Avatar
Now I get it. So, if you loosen the bolts up, will it flex more?
Old 07-09-2006, 08:11 PM   #12
NO it will axle wrap. That holds it rigid. The channel deflects and twists.
Old 07-09-2006, 09:05 PM   #13
First the side plates went away, then the shocks & springs went away, pretty soon we'll be crawling with no axles!
All of a sudden the Nanotube is old-school! I can't keep up with you guys.
microgoat is offline   Reply With Quote
Old 07-09-2006, 09:45 PM   #14
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Thats pretty slick! Does it articulate evenly to both directions and without a C shaped sway?
JohnRobHolmes is offline   Reply With Quote
Old 07-09-2006, 10:14 PM   #15
Looks good.
Old 07-10-2006, 03:14 PM   #16
Micro lol nano=old
Yes its even or so close I can't tell. My eyeball says yes though.
What do you mean"C shaped sway"
Old 07-10-2006, 03:21 PM   #17
Location: a place of settlement, activity, or residence.
Dude you amaze me sometimes. When do we get to see it in action? Des Moines again this weekend?
thaclodking is offline   Reply With Quote
Old 07-10-2006, 03:22 PM   #18
what is the ground clearance at? i have a plan ill have to try:-P ill let ya know what it is..later
Got Rocks? is offline   Reply With Quote
Old 07-10-2006, 03:26 PM   #19
JAy I'm going crawling in WI this weekend.
It depends on tires. Anywhere from 2.5" to 3.5"
Old 07-10-2006, 03:28 PM   #20
sweet thanks
